Bumper Vibration
Posted 23 December 2008 - 02:27 PM
It's a really low, serious sounding noise.
I was thinking that my subframes had exploded or something - but it's just the bumper.
When my mother in law had the car, it was gently reversed into by her neighbour.
This was enough to break the four spots and damage the bumper, but didn't hurt the grill.
I've got a spare bumper, but before I fit it - are there any tricks to make sure that it doesn't vibrate in the same way???
Cheers!
Posted 23 December 2008 - 03:29 PM
Posted 23 December 2008 - 03:49 PM
yeah, make sure the lip it attaches to has not comeaway from the front panel. Also use good sized washers and make sure everything is tightly done up!
Yer, my front one rattled too, and all it was, was that one of the nuts were missing and that the others were loose.
Posted 23 December 2008 - 07:57 PM
Posted 23 December 2008 - 08:00 PM
mine rattled as well I fixed it by putting rubber pads between the bumper and bodywork.
That was what I was thinking. Cool - B&Q here we come! (Although, in truth, it might be after the Xmas rush...!)
Posted 24 December 2008 - 11:08 PM
Posted 10 January 2009 - 11:45 PM
I removed the old dented bumper, found that one of the bolts had sheared, replaced with a spare bumper, and used rubber tap washers between it and the body.
Now all I have to solve is the bonnet rattle!
Posted 11 January 2009 - 10:43 AM
should only need a couple of turns, lock the nuts up and try and close the bonnet.
Also, make sure you have got the engine bay rubber seals around the inner wing edges, and a rubber seal on the the bonnet edge, under the lip, these often perish.
Posted 11 January 2009 - 12:53 PM
Edited by midridge2, 11 January 2009 - 12:54 PM.
