Fuel Tank For The Turbo
15 replies to this topic
#1 dannyg2325
dannyg2325
  • 434 posts
Posted 23 December 2008 - 04:55 PM
hi all,
nearly finished the turbo project now, thank god.
anyhoo, im using the tank from an spi mini, i was just wondering how i go about getting power to it?
can anyone help or do you have any pics/help threads!
many thanks all,
merry christmas!
danny
#2 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 23 December 2008 - 05:04 PM
Bear in mind that (apparently) "The SPI tank and pump aren’t really up to the job as they only put out 1 bar of pressure which means that if you intend to run more than 10psi of boost it won’t be able to supply the pressure you need."
As for power, you could take it off the fuse box.
#3 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 23 December 2008 - 08:28 PM
Yep i heard you need an MPi tank ideally or you need to run a seperate fuel pump?
#4 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 23 December 2008 - 11:38 PM
i've tested 4 or 5 spi pumps and all put out circa 1 bar (15psi ish) measured straight from the pump. so any more than 10psi boost is pushing it to be honest.
#5 dannyg2325
dannyg2325
  • 434 posts
Posted 30 December 2008 - 12:04 AM
hi guys thanks for the replies!
yeah i looked into it before i started, i dont intend on anything over 10psi, cars only really for show, but when i am driving its nice to have that wee bit of poke!!
so just take a new live feed from the fuse box and earth to the chassis?
thanks
ps, what would 10psi see me roughly?
#6 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 30 December 2008 - 12:54 AM
you need to run it through a relay, fuse and inertia switch really dude.
10psi could be anywhere between 80bhp and 120bhp depending on which rollers, who's tuned it, what parts are fitted etc
#7 dannyg2325
dannyg2325
  • 434 posts
Posted 30 December 2008 - 12:48 PM
hmm, where would i get an inertia switch from?
have you got any how to's on the fuel tank, the relay side of things and the switch kinda confuse me! lol
did u post any samples to me yet chris?? :wub:
thanks mate!!
#8 mini_lad_deacon
mini_lad_deacon
  • 277 posts
  • Local Club: tynemouth
Posted 13 January 2009 - 01:03 AM
can u use the metro turbo fuel pump and weld an extra pipe on standed tank for return? pros and cons?
#9 Ethel
  • 26,008 posts
Posted 13 January 2009 - 01:16 AM
You can use almost any remote mounting injection pump - pester a motor factors to check tech specs in their bosch catalogue. You don't need a return in to the tank if you Tee it in to the line between the tank and pump.
I'm sure there's a good diagram of the ERA mini pump wiring somewhere on the web - worth a google. Find the diagram and you'll see an inertia switch isn't essential, but not a bad idea 'n a trip to your local scrappers should uncover one.
#10 mini_lad_deacon
mini_lad_deacon
  • 277 posts
Posted 13 January 2009 - 01:20 AM
So what car would have a sutible pump because i got told u need a certain pressure...
#11 Ethel
  • 26,008 posts
Posted 13 January 2009 - 01:29 AM
You need 3-5psi more than the maximum boost you'll run. Virtually all injection systems will run at several bar, you'll need less than 2bar.
#12 mini_lad_deacon
mini_lad_deacon
  • 277 posts
Posted 13 January 2009 - 02:03 AM
im not planning on having the boost anymore than 7psi
#13 dannyg2325
dannyg2325
  • 434 posts
Posted 19 January 2009 - 11:58 AM
well i had a thought there, would it be possible to take live feed from the fuse box to a switch in the dash and then to the fuel tank.
meaning to start the car i would have to turn the key to ACC flick the switch for the fuel pump to come on then start the car.
im thinking this way for security, the car wont start unless the pump is activated?
im i being silly?
#14 gav
gav
  • 700 posts
Posted 19 January 2009 - 12:58 PM
The SPI tank will be fine for what you want and has a return so that's the easy bit. I've wired mine into the oil pressure switch using a relay for safety (so if you crash and the engine stops your pump will stop) it's also got an inertia switch to.
#15 wolfie
wolfie
  • 1,149 posts
Posted 09 February 2009 - 10:46 AM
try a scrappy, any zetec model escort or mondeo there in the kick panels secured by two screws
if you get stuck i do have a couple but will need time to find them
