Gunsons Exhaust Gas Tester
4 replies to this topic
#1 sven_2k4
sven_2k4
  • 188 posts
  • Local Club: na
Posted 24 December 2008 - 09:11 PM
Hey all,
just wondering if anyone out there in the Chester area has a Gunsons gas tesater i could borrow for a day to set the carb and timing up on emily.......
my snap on strobe says its 28 degrees out, although when i set it to the correct 8 btdc it runs like a bag of nails!
Granted its running on unleaded and ment to be a little bit further advanced but 20 degrees is pushing it.
Fueling seems to also have a flatish spot so a tester would be handy.
Also does anyone know what the best 'pre-tweaking' set up would be..... i.e 8-10 btdc and 3.5 C.O???
Many thanks
Edited by sven_2k4, 24 December 2008 - 09:28 PM.
#2 icklemini
icklemini
  • 2,982 posts
Posted 25 December 2008 - 09:07 PM
Um - you have disconnected (and plugged) the vac advance before trying to set the timing??
aye around there should get it going...
Edited by icklemini, 25 December 2008 - 09:08 PM.
#3 sven_2k4
sven_2k4
  • 188 posts
  • Local Club: na
Posted 26 December 2008 - 12:09 PM
Yup set the timing with the Vac advance disconnected and the revs set at 1500 as per the autodata sheets.
Seen a couple of exhaust testers on ebay MOT type and gunsons so i'll keep an eye on them.
#4 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 26 December 2008 - 12:29 PM
don't bother with the gunsons, will see if i can grab my old snap on meter from my mate. will give you a shout if i get hold of him over the next couple of days
#5 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 26 December 2008 - 04:32 PM
Don't bother with the gunsons
We picked one up off Ebay and it's been a god send. Works just fine and came up with the same levels that the MOT station did. Did everything you could ask it to.
