I don`t write English every day so i hope you will understand.
I have fitted a coil spring convertion on my mini, but the area where the rubber used to be are much larger than the coil spring.
Should the coil spring just lay where the rubber used to be? i muct be at least 1/2 inch where the spring could move around.
I have also fitted Hi lows rear and in front, back when i lift the car the whole hi low and spring get loose, is this also right or should i fasten it somehow?
In the front i think it rides wery high and i have the hi low in the bottom so shouldn?t it be wery low?
Hope you can help me.
Best regrads Mikael
Coil Springs
Micke G
, Dec 25 2008 12:29 PM
No replies to this topic
