Quarter Lights
8 replies to this topic
#1 westpark15
westpark15
  • 133 posts
  • Local Club: mini drivers club
Posted 25 December 2008 - 10:01 PM
~~~~~Please delete this text before posting the topic~~~~~~
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
Model: mini neon
Year:1991
i have got openening quarter lights is there any chance that you can change them to sealed quater lights?
thanks nigel
#2 RacingGreen
RacingGreen
  • 2,111 posts
Posted 25 December 2008 - 10:35 PM
Yes, its just a case of removing them, finding some fixed quarter light glass and the correct rubber and they will fit. The window aperture is the same.
#3 westpark15
westpark15
  • 133 posts
Posted 27 December 2008 - 02:01 PM
thanks do you know any one selling them ?
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 December 2008 - 02:17 PM
Most Mini specialists and all car glass dealers will sell them but currently they seem to be out of stock in most places. You'll have to try somewhere local as most specialists won't post glass anyway.
#5 westpark15
westpark15
  • 133 posts
Posted 27 December 2008 - 02:22 PM
thanks i wil try my local mini shops
#6 Southy
Southy
  • 1,579 posts
  • Local Club: Oldham and Distrcit Mini Club
Posted 27 December 2008 - 04:10 PM
Just remove your quarter light windows and then on the chrome strip around the edge unscrew the small grub screw and carefully remove the outter chrome surround and there you have it, your set of sealed rear quater windows, thats all i did with mine, the glass is exactly the same size.
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 December 2008 - 05:01 PM
No it isn't, it's a different piece cut to a different shape. The fixed piece is about 8mm smaller on each side than the opening type. I don't see any way that you could get an opening piece to fit into the aperture properly with a fixed type seal. The fixed piece sits within the aperture and the opening type fits up against the outside.
#8 Southy
Southy
  • 1,579 posts
Posted 27 December 2008 - 05:08 PM
Believe me its possible, mine fitted in perfectly no problems with no leaks at all and wasnt a tight fit as if the glass was too big.
#9 westpark15
westpark15
  • 133 posts
Posted 27 December 2008 - 05:25 PM
thanks i will try and buy some sealed ones then try doing it with the opening ones if it fits i can take them back :)
