Mk2 Rear Lights
11 replies to this topic
#1 RacingGreen
RacingGreen
  • 2,111 posts
Posted 31 July 2005 - 08:35 PM
I have been thinking of fitting Mk2 rear lights to my car because i want something a bit different and i just wondered how difficult it will be for me to convert from the standard lights on my mk4 to the mk2 light.
I know that i will need to fit a reversing light, but is the any other modifications i will need to do to get the lights to fit?
Mike
EDIT: Also, any idea where i can get a reversing light that will match the fog light?
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 31 July 2005 - 08:53 PM
its the same size hole so should fit straight in :smartass:
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 August 2005 - 07:35 AM
You may have to chage the connectors on the wiring, but apart from that straight swap, and you don't actually NEED a reversing lamp, but you will have to retain your fog lamp.
#4 austin68
austin68
  • 403 posts
Posted 01 August 2005 - 07:21 PM
Do you mean mk1 lights, the rounded kind?
If so you need to weld in some adapter plates, and wire up the new lights.
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 01 August 2005 - 07:28 PM
no he said MK2 lights :-
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 01 August 2005 - 07:29 PM
landrover defenders
#7 RacingGreen
RacingGreen
  • 2,111 posts
Posted 01 August 2005 - 07:47 PM
cheers bungle, found one, and a fog to match it! :grin:
Will it fit the mini fog mounting bracket?
#8 austin68
austin68
  • 403 posts
Didnt think mk2 lights were much different to later cars. But you live and learn.
:smartass:
#9 RacingGreen
RacingGreen
  • 2,111 posts
Posted 01 August 2005 - 07:50 PM
the mk2 lights were 1 piece lenses (as opposed to 2 piece) and didnt include the reversing lamp (which is the look im going for)
#10 austin68
austin68
  • 403 posts
Posted 01 August 2005 - 07:58 PM
Thanks Ive not looked that closely at them as im doing a mk1 conversion.
#11 Bungle
Bungle
    Original Spamster
  • 28,971 posts
if its the one im thinking of then its the same as a mini one :-
#12 RacingGreen
RacingGreen
  • 2,111 posts
Posted 01 August 2005 - 08:02 PM
yeah, just had a look, exactly the same as the fog. Thanks for all the help.
