Engine Problems
wakkoboi
, Dec 28 2008 05:51 PM
6 replies to this topic
Posted 28 December 2008 - 05:51 PM
Currently having a problem with the engine juddering quite a lot eith when it heats up or when it is having excess strain put on it such as going up a hill. I am currently thinking about decoking the head in hope to solve the problem. What does decoking involve? does anybody know what else it could be? what other routine service checks should i do?
Mike
Mike
Posted 28 December 2008 - 05:53 PM
Could it be running on 3 cylinders?
When were the electrics that replaced?
New spark plugs, ht leads, dizzy cap, rotor arm, contact breaker points and condenser may be all that's required here?
Posted 28 December 2008 - 06:00 PM
i thought about that, but why would it only do it once the engine was warm, would i not be able to here it whilst it was just idling?
Posted 28 December 2008 - 06:11 PM
Well you could try taking each of the ht leads off a spark plug one at a time and then if the engine note doesn't change on one or the other, then you'll know it's a spark plug/ht lead/electrical problem?
Be careful though as it's not funny receiving an electrical shock.
Edited by taffy1967, 28 December 2008 - 06:11 PM.
Posted 28 December 2008 - 06:12 PM
Well the engine isn't under load whilst it's idling?
But I'd check the electrics and then if the problem persists I'd consider the carb needs a tune or a rebuild.
Posted 28 December 2008 - 06:23 PM
ok thank you
Posted 28 December 2008 - 07:09 PM
this happened to me with my 998cc engine, found out it was the points that needed replacing
