Desprate Help Needed
Margie The Mini 1275
, Dec 29 2008 01:18 PM
4 replies to this topic
Posted 29 December 2008 - 01:18 PM
need desprate help bought a new MEMS engine management relay and fuel pump still wont work please help
Guest_ratty_*
Posted 29 December 2008 - 06:34 PM
Check the fuel pump cut off switch on the bulkhead
Edited by ratty, 29 December 2008 - 06:34 PM.
Posted 29 December 2008 - 07:30 PM
Is the part number on the relay pack the same as the one you removed? There are a few different types of this relay and they all look the same but aren't interchangeable.
Posted 29 December 2008 - 10:15 PM
yes it is the same
it is a YWB 10022
it wasnt working before but on the old one if you push the fuel pump switch it works but not on the ignition
thanks
any help appriciated need to get margie working again
it is a YWB 10022
thanks
Posted 29 December 2008 - 11:17 PM
You said the switch you were pressing before was in the relay pack, I assumed that meant you were pushing part of the relay pack that you had in bits so I thought you were manually closing the relay. If you mean that it works when you press the innertia switch but stops when you release it then all you probably need is a new innertia switch. It just sounds like the switch isn't latching.
