Rear Wheel Alignment Problems
8 replies to this topic
#1 Wild9
Wild9
  • 15 posts
Posted 30 December 2008 - 06:20 PM
Model:Mayfair
Year:1984
Description of problem (please be as in depth as possible): The rear wheels seem to be in a slant position. To be clear, when seen from the back of the car the wheels are like this.... | \ hope u got an idea from what I mean... so the right rear wheel are slanting towards the inside which causes my tyres to wear from the inside
Please help me guys
thanks a lot dear.
Any non-standard parts that might be involved with the problem? None.Its original set up but seems that my shock absorbers are dead.
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 30 December 2008 - 06:22 PM
Sounds like your trailing arms are shot to me. When were they last greased? If they haven't been done for a while the bearings may well have collapsed. Another possibility is that the trailing arm mounting holes in the subframe are worn.
Edited by Dan, 30 December 2008 - 06:23 PM.
#3 blacktulip
blacktulip
  • 6,224 posts
Posted 30 December 2008 - 06:32 PM
be very carefull, if they are pointing forwards away from the car its deemed as VERY dangerous on corners as the rear would try to overtake the front and an inevitable ditch will be found. they need to be pointing slightly.
#4 Boycie
Boycie
  • 1,978 posts
Posted 30 December 2008 - 06:59 PM
Check for movement in the arm.
It's probably a bent radius arm from a kerb-clouting incident in the past.
Change by all means, but unfortunately jobs like this on otherwise original cars end up going from simple arm swap to.......
Radius Arms x2
Rear subframe
Rear doughnuts
Brake pipes
Brake backplates
Wheel cylinders
Welding boot floor etc etc :wub:
You get me?!
#5 Wild9
Wild9
  • 15 posts
Posted 01 January 2009 - 06:42 PM
Radius Arms x2
Rear subframe
Rear doughnuts
Brake pipes
Brake backplates
Wheel cylinders
Welding boot floor etc etc :thumbsup:
You get me?!
he he
well thanx a lot mated
Yea got a picture of the actual situation
will try to get repaired and keep u updated
Happy New Year to all
#6 Boycie
Boycie
  • 1,978 posts
Posted 01 January 2009 - 07:23 PM
Stick the picture up if you can mate, good luck with it.
#7 MUNGO
MUNGO
  • 35 posts
  • Local Club: www.sunshineminis.org
Posted 02 January 2009 - 08:49 PM
I think I might have the same problem.
#8 jakson
jakson
  • 42 posts
Posted 03 January 2009 - 10:51 PM
hi my rear wheels point like this \----/ is this bad if so how do i go around fixing it?
#9 icklemini
icklemini
  • 2,982 posts
Posted 04 January 2009 - 01:28 AM
positive camber at the back is standard (upto 2 1/2 degs!)
to adjust you can get brackets to adjust camber and toe.
hth,
Dave
