Carb'd Mpi
6 replies to this topic
#1 l_jonez
l_jonez
  • 1,453 posts
Posted 30 December 2008 - 08:56 PM
i've had a quick search thru the forum and could not find any conclusive answer, any ways heres my plan..
i currently have a spare complete MPI engine sat in my garage. i already have every thing needed to convert it to a carb along with a megajolt off my old engine.
so what im planning is to strip all the sensors vacume hoses etc and replace with a carb and megajolt. personaly i cant see any problems with this but does any one know if its not posible? as i'd rather know now lol
the engine will be going in an early mini so emissions wont be a problem.
many thanks
l jonez
#2 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 30 December 2008 - 09:08 PM
You will need an electric fuel pump, and somehwere to fit the coolant temp sender. also need to use the MPi alternator and drive belts otherwise you need to fabricate some sort of alternator bracketry
#3 l_jonez
l_jonez
  • 1,453 posts
Posted 30 December 2008 - 09:17 PM
yep got a fuel pump and the engine still has alternator etc fitted, looks like its just sorting the temp sender out, will have to give that one a bit of thought
#4 Sprocket
Sprocket
  • 7,266 posts
Posted 30 December 2008 - 09:23 PM
Only other problem is fitting a 36-1 crank sensor to the engine for the Megajolt
#5 l_jonez
l_jonez
  • 1,453 posts
Posted 30 December 2008 - 09:34 PM
that should not really be a problem i've fabricated my own for 5 ( 2x998 3x1275) engines so far. the extra width of the pully might cause a clearance problem if i go for a side mounted rad tho :withstupid:
#6 stardude
stardude
  • 2,457 posts
  • Local Club: hilltop mini's
Posted 30 December 2008 - 10:12 PM
arnt the emmisions tested against the age of the engine? and not the age of the car though?
#7 Ethel
  • 26,088 posts
Posted 30 December 2008 - 10:16 PM
Luckily, they go by whichever is the older.
Have you thought of modding the MPI crank sensor wheel? That'd be really tidy :withstupid:
