Spi Vacuum Connections
Posted 02 January 2009 - 01:43 PM
I have a 1991 SPi Cooper, I have noticed that there are two vacuum connections at the back of the throttle body.
One goes to the thermal valve on the air filter however I cant find where the other one connects to, currently
this is open allowing air in to the body of the throttle below the throttle plate.
Anyone know if this should be blanked off or connected to something as I cant find anything obvious.
Mike S.
Posted 02 January 2009 - 01:58 PM
Hi,
Mike S.
I may be mistaken, and I'm sure others will say so, but the other one goes to the fuel trap (held to the left (facing engine) and under the air filter housing) and then a hose from that goes to your ECU..
Posted 02 January 2009 - 03:11 PM
Rob
Posted 02 January 2009 - 03:34 PM
Hi,
Mike S.
Couldnt find the fuel trap but did find the hose from the MEMS unit, must have come adrift at some point. Connected it up to the throttle body and the misfire, black smoke etc. all went away, now running well again. So I'll have to get a fuel trap ordered up and connect it back together properly.
Thanks,
Mike S.
Posted 02 January 2009 - 06:19 PM
I don't have a picture handy - perhaps someone else does? - the fuel trap is mounted on the firewall behind and to the driver's-right of the engine. There should be a little mount with two tabs on either side, and a tab on top, perhaps 2 inches (~50mm) wide - it's small.Couldnt find the fuel trap but did find the hose from the MEMS unit, must have come adrift at some point. Connected it up to the throttle body and the misfire, black smoke etc. all went away, now running well again. So I'll have to get a fuel trap ordered up and connect it back together properly.
Thanks,
Mike S.
My gut instinct says to be careful driving it without a fuel/oil trap, as if your ECU gets a lot of it in there, it could damage it. But, I'm not 100% on that, so..
Posted 02 January 2009 - 07:25 PM
even with a fuel trap connected i clean this (hole where hose goes into ecu) out occasionally, i use a bit of rolled up tissue, a lot of people will say leave it on a radiator overnight and the nastiness kinda oozes out but i've never had time to try this
Posted 03 January 2009 - 08:56 PM
I've honestly never cleaned mine - I think that's on my to-do list. Other than a connector breaking, I haven't had a problem with these (two) hoses, so I'm curious as to how much 'gunk' I will have in there.. hmm..as above about being careful driving it like that for now, im not sure how much/if it will damage the ecu, but even with the fuel trap connected you can get fuel blocking the hose where it enters the ecu (im assuming not having fuel trap will speed up this build up)
Posted 03 January 2009 - 09:09 PM
i cant say if it made a lot of difference as i've had a blowing exaust forever
Posted 03 January 2009 - 09:16 PM
Posted 03 January 2009 - 09:31 PM
Ah, good point. It never occured to me, since I've seen posts on how to clean the ECU's sensor, but never anything on cleaning the fuel trap (which would seem to need cleaning more often than the ECU!)its most likly to block up on the injection mount (fuel manifold ) side as the filter will keep the ecu side clean
Posted 11 January 2009 - 03:33 PM
Posted 11 January 2009 - 09:22 PM
The fuel trap is here and has a green and a black connection, any idea which one goes to the throttle body and MEMS module?
Green goes to ECU. Black goes to manifold.
.. at least that's how it is on my car. '92 SPi.
Posted 12 January 2009 - 07:38 PM
Magic, thanks.
Posted 12 January 2009 - 07:48 PM
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/grin.gif)
Posted 13 January 2009 - 10:55 PM
I'd wager a guess because the fuel evaporates. I may have to try that, see if I notice a difference now.when mines running a bit rough i take the fuel trap off leave it on a warm radiator over night, works a treat dont ask me why because i dont know
