but one thing that will sway me either way is the price
thanks for looking any advice is better than none
thanks
Posted 07 January 2009 - 12:45 AM
Posted 07 January 2009 - 12:58 PM
Posted 07 January 2009 - 03:22 PM
the difference in price between a 1275 stage 1 and a 120bhp 998 turbo is probably about £6000.
you could pick up a complete 1275 stage 1 for 2-300 and if its been looked after and its a reasonable milage, it'll run without any major problems for up to 100k... if you expect to get 10k out of a 120bhp 998 you're having a laugh, it'll need rebuilding every 3 sets of traffic lights.
my advice would be to forget turbos, it wasnt a good idea when rover put them on and it still isnt now. 1275, a nice cam, ported head and a hif44 should do you fine and run reliably enough for a daily drive, if you're lucky you might see 80 ponies at the fly on a mild tune 1275. Incase you were wondering, a good 1275 with a stage 1 kit will hit around 60bhp and 65lbft.
hope that helps
Posted 07 January 2009 - 07:36 PM
hope that helps
Posted 07 January 2009 - 10:49 PM
Edited by rozzer1275, 07 January 2009 - 10:56 PM.
Posted 08 January 2009 - 12:37 PM
hope that helps
There is so much wrong with what you say here. You seem to have a general exception to turbos, why is this? The turbo is a fantastic addition to the A-series. If done properly you can get great power and great MPG. All this and the longevity of the engine is no less than a high power normally aspirated engine.
Edited by haz, 08 January 2009 - 12:38 PM.
Posted 08 January 2009 - 12:47 PM
Posted 08 January 2009 - 12:51 PM
hope that helps
Well, let me put it this way... you wouldnt run a turbo off your gearbox oil in a modern car would you? Its probably the most rediculous peice of automotive engineering I've ever come accross. An afterthought botch is what it is! I'm not saying they dont work because they do, and im not saying you cant get good power out of them, because you can. What I am saying is that its not a good idea for a daily driver, longevity IS the issue and they are renound for their lack there of. Maybe if you ran some kind of stand alone slosh tank you could avoid the swarf issue, i dunno, its too much of a headache... stick n/a with the A-series for my money. Having said that, I cant comment on the charger route as its not something im familar with, other than they're expensive and require plenty of fettling...
Edited by mini_mission, 08 January 2009 - 12:52 PM.
Posted 08 January 2009 - 12:52 PM
Posted 08 January 2009 - 01:04 PM
A chap on here called bud666 will completely disagree- I believe he is running 160 ponies with a bog standard bottom end, cheapo pistons and as a daily driver with no problems. the key, as with any high performance a series, is maintenance.
Plus, there is no need to rev the tatties off it.
Posted 08 January 2009 - 06:33 PM
Posted 08 January 2009 - 07:05 PM
Posted 08 January 2009 - 07:07 PM
Edited by john1.2pearl, 08 January 2009 - 07:36 PM.
Posted 08 January 2009 - 07:32 PM
Posted 08 January 2009 - 07:46 PM
