Heater Fan Not Working
7 replies to this topic
#1 Clubber Lang
Clubber Lang
  • 746 posts
Posted 07 January 2009 - 06:03 PM
1991 mini city'ish
The heater is getting warm but not blowing, has the fan motor gone? can it be replaced without removing bthe complete heater? I have checked the fuse and switch so neverything is pointing to the fan motor unless you have any ideas please? cheers Tom
#2 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 07 January 2009 - 06:06 PM
Do your 'Windscreen Wipers, Washer Motor & Instruments' work, because they run on the same circuit as the heater.
You could try cleaning up the fuse box as the rear terminals do get very rusty with age and it could just be a bad connection.
But if the fan motor is dead, then the whole heater assembly will have to come out to be stripped down. Pretty easy task though.
#3 Clubber Lang
Clubber Lang
  • 746 posts
Posted 07 January 2009 - 06:18 PM
Instruments workwipers etc. work, fuse box o.k. so looks like fan motor.
Does the dash have to come out ? got anothercar in my garage at present so may have to take it to a mechani :D c
How much will it cost? regards Tom
#4 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 07 January 2009 - 06:23 PM
Just buy a Mini Haynes manual and do it yourself and no the whole dash doesn't have to come out.
Take a look at this thread as I explained what needs doing here: -
http://www.theminifo...l=heater remove
#5 Clubber Lang
Clubber Lang
  • 746 posts
Posted 07 January 2009 - 07:06 PM
Cheers Taffy, just been on the minispares site :D must be the most expensive bit on the car! £247!!!!!! just for the fan motor.
Gonna take it off and if its fubared i'll have to look for a second hand one. :-
#6 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 07 January 2009 - 07:51 PM
Yes I remember sourcing a good second hand replacement heater fan motor for my sisters old Mini.
It cost no more than about 20 quid from my local Mini specialist who stocks new and used parts.
Edited by taffy1967, 07 January 2009 - 07:53 PM.
#7 Brigbeale
Brigbeale
  • 287 posts
  • Local Club: Bournemouth Mini Club
Posted 09 January 2009 - 07:53 PM
Before taking the heater out, check the switch is Ok.
I had an intermittent motor a few years ago and it was the connectors on the switch had become loose. I crimped them back into shape to make them tighter and the problem was solved.
Try bridging the wires to eliminate a faulty switch.
Also check the earth???
#8 andyapanel
andyapanel
  • 625 posts
Posted 11 January 2009 - 12:46 PM
I had a similar problem last week. It turned out the fuse "grips" were an ever so slightly loose fit : enough current was getting through for all the instruments on the circuit except the fan motor, which I guess has a much greater demand. Solution was to pinch the tangs of the grips to make a tighter grip on the fuse.
