My Mini Smells Of Petrol:(((
10 replies to this topic
#1 stussymini
stussymini
  • 37 posts
Posted 07 January 2009 - 11:31 PM
first of all...hi everybody i'm new on here and new to mini...
just wanted to know if anybody can give me a tip..i had my mini already checked by a mechanic which said i had a petrol leak and apparently fixed it.
well..
the smell its not inside the car, when i drive with the window up, but if i get the window open the smell of petrol becomes quite overpowering...so it seams to be coming inn from outside if the engine its on.
sounds familiar to any of u/ur minis?
i'm kind of not bother by it now (..as its bloody freezing..), but i'd like to get it fixed by spring time..
also my boot really smell of petrol..is it common?
thanks in advance to anyone that can help or suggest something...and nice to meet u all :P
#2 blacktulip
blacktulip
  • 6,224 posts
Posted 07 January 2009 - 11:41 PM
start the car and shine a torch down the back of the engine by the pump. i had a leak here a few weeks ago. also check the condition of the hoses and clips plus the vent pipe on the petrol tank in the boot.
#3 Ell100
Ell100
  • 517 posts
Posted 08 January 2009 - 12:54 AM
there should be a pipe going from the top of your tank leading out the bottom of the boot, its a breather pipe, chances are its not there so you'll have to stick another one on!
#4 Bec
Bec
  • 5,900 posts
Posted 08 January 2009 - 08:02 AM
Another check you could make is the petrol cap itself, my mini smelt really strong outside of petrol and that's where it was tracked down to as the seal had gone.
#5 Jackman
Jackman
  • 4,053 posts
Posted 08 January 2009 - 08:11 AM
Id check your breather pipe in the boot, make sure its not come loose.
#6 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 08 January 2009 - 08:12 AM
Did the mechanic tell you where the leak was? If it was carb overflow it may have soaked the sound proofing.
Alternatives are failed pump joint, carb overflowing still, split hose, (though you haven't said the car is having problems with power), fuel cap.
If it was fuel tank breather I'd expect the fumes all the time.
Get it fixed asap as the fumes aren't good for you! Plus if there's a petrol leak there's a significant fire risk!
#7 Jackman
Jackman
  • 4,053 posts
Posted 08 January 2009 - 08:21 AM
Its because he said he said the boot smelt of petrol and it came in when he opened the window. Its somthing to check and cross off though.
#8 megabob
megabob
  • 207 posts
  • Local Club: South West Mini's
Posted 08 January 2009 - 10:23 AM
the fixings have to be very tight and ive discovered that juiblee clips do not work very well, but if you get a consistant leak then you sometimes get a white crystal like disposit from where ever the leak is coming from
#9 mister bridger
mister bridger
  • 911 posts
Posted 08 January 2009 - 10:28 AM
I had a leak from the sender unit on the tank in the boot. Its a bayonet type fitting with a rubber seal that had perished.
#10 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 08 January 2009 - 07:22 PM
I bet it's the fuel tank vent pipe has come adrift from the fitting on the top of the fuel tank.
Refit it and make sure it's not kinked and is able to exit through the boot floor rubber grommet.
It runs through the hole with the grommet (behind the fuel tank, the other hole with no grommet is for the fuel hose): -
How it appears beneath the boot floor: -
#11 stussymini
stussymini
  • 37 posts
Posted 08 January 2009 - 11:42 PM
hey guys...thanks to all for the tips..wow..u all very clued up...i will check all that u wrote so far next week end and then i will post outcome.. ;D
big big thank
