Can anyone identify this servo from the picture below?
Im having a problem with the brakes and need to order a servo repair kit but dont know which one to order.
I know its a lockheed but need to know the correct model.
Thanks.
Posted 09 January 2009 - 05:55 AM
Posted 09 January 2009 - 09:10 AM
Edited by GuessWorks.co.uk, 09 January 2009 - 09:15 AM.
Posted 09 January 2009 - 09:37 AM
Posted 09 January 2009 - 09:49 AM
Posted 09 January 2009 - 11:12 AM
it's a Mk2 (type 6) servo ( that's not as in mk2 mini ), first fitted to the MK3 cooper S and 1275GT, it's a remote servo fitted to a single line brake system, so what it's doing connected to a tandam system I don't know as that means the servo is only acting on half the system, which may be the brunt of your problems.
Edited by Asphalt, 09 January 2009 - 11:37 AM.
Posted 10 January 2009 - 03:22 PM
There is no way of fitting a remote servo to a tandem system, because the front/rear ( or even worse diagonal) split is done at the master cylinder.
What seems to have been done there is, both outputs have been joined by the T piece, through the servo, and then split again by a "T", essentially making it a single line system. Bit unorthodox..
IMO, you'd be much better off, removing the servo altogether, they don't increase breaking efficiency, reduce pedal feel and generally get in the way when you want to do anything on the engine.
Posted 10 January 2009 - 05:00 PM
Edited by sprintmini, 10 January 2009 - 05:01 PM.
Posted 10 January 2009 - 05:06 PM
Posted 10 January 2009 - 05:12 PM
Posted 10 January 2009 - 06:10 PM
Posted 10 January 2009 - 06:49 PM
