Mobile Phone Controlled Switch?
Posted 10 January 2009 - 11:39 AM
I'm thinking about getting a heater for my garage as it's freezing!
My garage isn't at home but ideally I'd like to switch it on 20mins before I get there so it's nice and welcoming for me to start work.
I was thinking about a timer... but I don't go to my garage at regular times, therefore a timer wouldn't be much good.
Has anyone ever seen a mobile phone controlled type timer switch? Something that I could perhaps send a text message to for switch on/switch off? It would be the perfect solution. Ideally it needs to be something that doesn't cost the earth too.
Ed
Posted 10 January 2009 - 12:05 PM
Posted 10 January 2009 - 12:36 PM
Just got to find some Al-Qaeda dude to make me one!
Posted 10 January 2009 - 12:39 PM
Use a old mobile phone and ring it when you want to switch it on??
Posted 10 January 2009 - 12:41 PM
Old mobile strapped to a light dependent switch (or a mercury switch if it does vibrate) should suffice to remotely burn your garage down. Some form of timer to turn it off would be sensible. Radiative, as in old style bathroom heaters, are good for garages.
Your find is 220v so compatible with the UK power supply just needs an adapter socket - assuming it can handle the current a heater would draw, likely does.
Posted 10 January 2009 - 12:44 PM
That could be the last we hear from Ed if he googles that!
When you set this up, make sure that you post the number on the forum...
Posted 10 January 2009 - 12:47 PM
I'd switch it on about something like 10mins before going to the garage. The garage is quite big (slightly more than double width and triple length) so I'd put the heater away from anything else.
I could have it on an auto timer to switch after 15mins if I end up not going to the garage for some reason.
All that seems fairly safe to me.
Posted 10 January 2009 - 12:50 PM
Something like this
http://www.cottnertechnologies.com/
Yeah that seems to be exactly what I'm after! I was kind of hoping that it wouldn't cost quite so much though
If they're all going to be that expensive then they are definitely out of my price range
Posted 10 January 2009 - 12:53 PM
http://www.rapidonli...ed-switch/74248
Jordie, only just saw your link.. that looks great! Wonder how to wire it up to a mains appliance?
Posted 10 January 2009 - 01:04 PM
I was only teasing over the burn your garage down quip, but do consider that anything could happen while you're not there - So go ott with precautions, like putting the heater in a cage.
Posted 10 January 2009 - 01:09 PM
Posted 10 January 2009 - 01:24 PM
