1993 Rover
Well, here goes. My car is wonderful, it's fast, responsive, it's been awesome in the cold and the wet, doesnt let me down when I need it. HOWEVER, When i'm going down the motorway, cruising at 60 for about 20 mins until I get to the junction I need, when I put my clutch down the revs drop as normal, to about 900rpm, but sometimes they then keep going lower and stalls, but it will start up again right away
The engine does try to recover itself and 7/10 times it keeps running long enough for me to pull off and keep the revs up myself. The general performance seems unaffected, it's only after it's been at 3000rpm or higher for a long period that this problem occours
I mean, sometimes it doesnt stall out, which is the bit that confuses me. I have noticed something before it stalls though. I have a vacuum guage and it usually idles at 21 (nice healthy air intake) but it seems to go down to 15-10 before it stalls out. I have a K&N style filter on it, so I dont think there would be much chance of a blockage and besides, if there was a blockage, then it would stall out every time wouldn't it?
Have any of you experienced anything like this? is there anything I could replace or check?
The idle when it's behaving is fine at about 900rpm and adjusting it (as I have tried once) doesn't solve this problem
Edited by Ajay, 10 January 2009 - 12:20 PM.
