the tasks on the list for yesterday were to fit the 6*9s in the parcel shelf, connect up the fog and reversing light, fit he dash and get the bit around the rear window primered. I didn't get the dash done ... because it didn't fit first time and I ran out of time, or should I say light.
As for the rest ... I started by marking the holes for the speakers, only to discover that I did not have metal blades for the jigsaw ... so that was put on hold.
I then went to mix up some filler and use it to repair some sections around the read window ... it takes quite long to dry when cold.
To fill the time I tried to solder the wires for the fog and reversing light but the wires coming out from the car are old and didn't like being soldered. We had the same problem last week with Justin when we connected up the front indicators.
So, once the shops had opened I went down to Wickes and Halfords and got some bits and pieces. When I got back home I had a break for lunch with the family.
Back in the garage I cut the holes for the speakers ... quite scary to cut metal (first time I've done it) but it worked and they fit. Need to get some bolts and nuts though, the self tapping screws that came with the speakers won't hold them in place for long I would guess.
The fog and reversing light then got treated to some bullet connectors which worked quite well, though here is a lot of wire to be hidden behind the bumper. I might go back and cut some of it off at a later stage.
All of this had given the filler enough time to dry so out came the sandpaper and a bit later the air was filled with dust ... but the window surround looked a lot better. Cleaned with some white spirit, surrounded with masking tape and newspaper the first layer of primer went on.
Whilst that was drying I tried to fit the dash. It looks like the middle part sits in front of the oval dash, so there is no need to take that out. That fits okay, not perfect but it should work. The right hand panel went in with a bit of pusing and shoving ... but the passenger side one refused to go in. Not quite true, it kind of went in between the metal at the top and the bottom but not far enough to the left hand side for the screw to line up with the hole in the center piece. I played around for about 20 mins and then put another coat of primer onto the back of the car. After that it was just after 5pm and it got a bit dark so I decided to call it a day.
Here's a couple of pics of the day's progress
