Cecil
54 replies to this topic
#31 warhonowicz
warhonowicz
  • 180 posts
Posted 29 August 2009 - 07:08 PM
right, Alec came round to help with the engine but also did help with some other bits, so this is where it stands now:
hand brake is working
indicator is working
engine is runnig more smoothly
outstanding
seat brackets
spacer for one rear wheel
small oil leak
#32 warhonowicz
warhonowicz
  • 180 posts
Posted 31 August 2009 - 07:28 PM
small steps but mostly in the right direction ... so I wirebrushed both spacers and gave them a quick coat of silver paint then put them onto the car. Next I put the back wheels back on and lowered the car back to the ground only to then put the front onto axle stands.
The indicator is now mounted back where it should be, the air filter is back on the carbs and I managed to get the screw out that might be the cause of the oil leak ... not looking good though. Since I didn't have a replacement I left it out so I can think about what to do with it.
Attached File  screw.jpg   227.26K   4 downloads
I then attached both bottom engine steadies to the engine, though not to the subframe yet as I was suffering from a lack of time and the correct drill bit. The left one (below the clutch) was a bit odd though. It should be secured with three nuts but would only fit onto two of them. The third one, the highest one of the three just didn't fit. For the time being I used just the two nuts and left the third where it was, which was no problem. Again, will have to think about it.
#33 GottaDesigner
GottaDesigner
    The Brains Behind TMF's Secret Santa
  • 1,394 posts
Posted 31 August 2009 - 08:06 PM
I know this car.... Jag emblem on the steering wheel, right? Green tinted glass?
#34 warhonowicz
warhonowicz
  • 180 posts
Posted 31 August 2009 - 09:14 PM
yes, thought the steering wheel is a different one now and the glass isn't really green tinted
#35 GottaDesigner
GottaDesigner
  • 1,394 posts
Posted 31 August 2009 - 09:40 PM
Hehehe. Thought so, I went out to do an interview (that never got published) with the chap you've brought it off for one of the mags after he'd finished the resto work... it was a beautiful little thing. The twin carbs gave him fits to set up :tumble:
#36 warhonowicz
warhonowicz
  • 180 posts
Posted 01 September 2009 - 07:26 AM
the car actually was featured in Mini Mag at one point ... still got the twin carbs but now on a 1293 instead of the 998
#37 warhonowicz
warhonowicz
  • 180 posts
Posted 07 September 2009 - 09:44 AM
So, on Saturday Adam came round to weld in some patches for the seat brackets to attach to. We cut square bits of metal, drilled holes for the brackets and then welded the nuts to the metal. He then drilled out the holes in the cross member and welded the new squares onto it.
He also put a small weld over the bit where the handbrake attaches to the cross member as that had come off.
I then put some primer of the new welds but will probably treat the whole floor to some wire brushing and Hammerite in the near future.
So, all that needs doing now is a new screw put into the timing chain cover and then I will try for an MOT probably (if they have a slot left) next Monday as I have that day off.
#38 minimininut
minimininut
    Look Out For My Haynes Minature Engine Install Project
  • 830 posts
Posted 07 September 2009 - 09:51 AM
Good work, I think Cecil is great! Fingers crossed for the MOT :thumbsup:
#39 warhonowicz
warhonowicz
  • 180 posts
Posted 07 September 2009 - 10:53 AM
Thanks to Giacomo from www.redandwhite.it I now also know what make the steering wheel is that I have been using since I first bought it for my first Mini.
It's made by a company called OBA and is the model cisa, which is a reference to Footstep of the Cisa (in italian: Passo della Cisa), famous footstep among Italian region Toscana and Emilia Romagna, once centre of race from place Poggio Berceto to Passo della Cisa. The Passo della Cisa is here where the dotted line crosses the yellow road.
OBA are still making steering wheels for cars and boats and also some other accessories.
#40 warhonowicz
warhonowicz
  • 180 posts
Posted 08 September 2009 - 01:35 PM
MOT booked for Monday morning 8.30 am
#41 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 08 September 2009 - 03:08 PM
Good luck :)
#42 warhonowicz
warhonowicz
  • 180 posts
Posted 10 September 2009 - 03:12 PM
so I went to the DVLA today with the V5, the invoice from MiniSpeed for the work to bore the new engine from 1275 to 1293, the DVLA letter acknowledging that I had scrapped the Metro and a hand written note that I had done the transplant myself. My aim: to get the new engine no and size into the V5.
A compliment to the DVLA Borehamwood, very nice staff, very helpful and very confident that it should be no problem. So, we'll see ...
#43 warhonowicz
warhonowicz
  • 180 posts
Posted 14 September 2009 - 09:26 AM
failed :D(
offside front cv gaiter come off (where have I seen that before)
engine idle too high
rear brakes binding, no handbrake and rear wheel bearings not tested
also, though he said if it had been just these we could have done it there
offside headlamp too high
windscreen washer not working
#44 minimininut
minimininut
  • 830 posts
Posted 14 September 2009 - 09:33 AM
Bad news, poor Cecil :D
Hope you managed to get the stuff done and he passes with flying colours really soon .... :)
#45 shedonwheels
shedonwheels
  • 821 posts
Posted 14 September 2009 - 07:12 PM
Oh dear, as above poor old Cecil.
Have you left him with the garage to be fixed? Hope he passes soon, he is absolutely gorgeous!
