Cecil
54 replies to this topic
#46 warhonowicz
warhonowicz
  • 180 posts
Posted 15 September 2009 - 07:52 AM
will do the work myself, got 10 working days to get the re-test done at half price, so will be busy this weekend, nothing in there that's terribly difficult
#47 warhonowicz
warhonowicz
  • 180 posts
Posted 21 September 2009 - 04:35 PM
did some work on Sunday, my new best friend, Mr Metal Cable tie helped me with the CV gaitor, I re-adjusted the rear brakes and got the screen wash to work. It was a mix of no water and a hose come off, which also explains the water we had coming into the car when we put the new engine in as we moved the water bottle temporarily out of the way which must have dislodged the pipe.
All that remains now is the headlight (tonight, when dark) and the carbs. Though the tester said if it was only the carbs it would be okay.
Re-test is booked for Wednesday morning ... wish me luck
#48 warhonowicz
warhonowicz
  • 180 posts
Posted 23 September 2009 - 07:20 AM
no MOT, wouldn't even start ... I think I'll leave it for a while
#49 Teapot
Teapot
    TMF Legend
  • 5,010 posts
Posted 23 September 2009 - 07:44 AM
:thumbsup:
Any idea for why it not go start?
I've just read the whole thread again. Courage! Good cup of tea!
#50 warhonowicz
warhonowicz
  • 180 posts
Posted 23 September 2009 - 10:02 AM
not really, I adjusted the light last night and it started first time, I then disconnected the battery and left it. This morning, reconnected the battery, tried and it just would not start
#51 warhonowicz
warhonowicz
  • 180 posts
Posted 02 November 2009 - 05:24 PM
long time no write ... tides have turned a bit again, so I now have little time to do anything with Cecil
on the plus side, I have an MOT! took a bit of work but got there in the end, so now I need to sort the oil leak, replace the steering rack gaiters (dangerously close to failing the MOT on that) and then enjoy driving ... probably next year
#52 warhonowicz
warhonowicz
  • 180 posts
Posted 03 January 2010 - 02:35 PM
After I got the MOT done I started having problems which meant I had no reverse gear, simply could not select it ... so back to the drawing board it was ... first Christmas had to be dealt with though.
Alec came over and we took the engine out today. He had an idea what the problem with reverse could be, turned out it wasn't that so we brought the gearbox over to his house for him to play with it. We also took of the gearchange thingy from under the car so he can try to make a modified bracket for it in order to fit the exhaust properly.
Oh, and of course we also took off the timing chain cover to hopefully fit it back without a leak when it all goes back together.
#53 warhonowicz
warhonowicz
  • 180 posts
Posted 11 January 2010 - 08:28 AM
so, it's all back together. Turned out the problem was the gear change mechanism and the way it was mounted to the underside of the car. After we stripped the gearbox, replace a few bits and bobs and put it all back, reverse still did not want to go in. Playing around, we discovered that with a few washers it suddenly did go in.
Just in case anyone is interested, Alec fabricated this mounting bracket
and welded this bit of steel into place
We also managed to fit the centre exhaust
#54 tedmcedd
tedmcedd
  • 2,751 posts
Posted 16 January 2010 - 12:10 AM
love this car!! the colour is amazing! may have to do mine this colour when it comes to paint!
#55 Jonesey
Jonesey
    previously known as paaulz
  • 53 posts
Posted 01 January 2012 - 02:24 PM
I love Cecil! :D Love the colour!
Edited by paaulz, 01 January 2012 - 02:25 PM.
