Rear Brake Back Plate Bolts?
11 replies to this topic
#1 plally
plally
  • 148 posts
Posted 10 January 2009 - 09:22 PM
hi, does anybody know the right size bolts that should hold the back plate on to the radius arms? or can you just put any ones that fit in?
#2 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 10 January 2009 - 10:23 PM
Check out the pdf shop files on Somerford Minis as they'll provide the information there.
#3 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 11 January 2009 - 06:48 PM
So do you see what you're looking for here: -
http://www.somerford...-RubberCone.pdf
Or here?: -
http://www.somerford...0-Subframes.pdf
Price list: -
http://www.somerford...-Price-List.pdf
#4 plally
plally
  • 148 posts
Posted 11 January 2009 - 09:38 PM
thanks taffy, but for sum reason nothing comes up when i go to the pdf file i want, on there web site. only the price list will come up, dont know why.
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 11 January 2009 - 10:54 PM
1 1/2" X 1/2"af UNF
#6 GraemeC
GraemeC
  • 7,440 posts
Posted 12 January 2009 - 08:46 AM
1 1/2" X 1/2"af UNF
......................... :shifty:
*melons* me, how thick are the backplates on your car??!! :-
Correct size is:
1/4" UNF x 5/8" long.
SPanner size is 1/2" AF
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 January 2009 - 09:07 AM
5/16 UNF x 1" actually :-
Would recommend using a nyloc nut as well.
I assume we're talking about the nut and bolt combinations which attach the backplate to the radius arm.
P/N GHF103
#8 GraemeC
GraemeC
  • 7,440 posts
Posted 12 January 2009 - 10:38 AM
My apologies, it is indeed GHF103 at 5/16 UNF x 1" long - I was looking at the front brake backplates by mistake.
I also misread the thread size - all-in-all it was a poor post! :-
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 January 2009 - 10:46 AM
It was early... :shifty:
#10 plally
plally
  • 148 posts
Posted 12 January 2009 - 05:24 PM
cheers everybody!!
#11 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 12 January 2009 - 07:53 PM
Strange, they work okay for me?
Just try loading them one at a time.
#12 mk1leg
mk1leg
  • 9,343 posts
Posted 13 January 2009 - 11:44 PM
1 1/2" X 1/2"af UNF
......................... ;D
*melons* me, how thick are the backplates on your car??!! ;D
Correct size is:
AF means accross flats IE 1/2"=5/16" UNF (unified fine) thread............... :D
