Year: 1982
* Carb cleaned, float needle/valve replaced, gaskets replaced. Carb set to two turns off level as per instructions.
* Points adjusted and double checked - all correct.
* Water found in distributer cap and over points (left in rain for short time *ahem*) - this was dried out and WD40 used.
* Water removed from each of the HT caps on back of dizzy cap and made firm.
* Engine idles fine, speed adjusted as per manual.
* As soon as throttle pedal engaged engine bogs down and dies.
* Replaced dashpot oil with 3-1 'handy oil' (very light) and got same result.
* Replaced dashpot oil with clean engine oil and got same result.
* Each time engine would only increase speed if choke fully engaged - however each time with choke out any further action on throttle bogged the engine again and would die instantly.
*Increased mixture setting on jet - enriched mixture one turn at a time upto approx 8 turns - no change.
Only way I can increase engine speed without bogging down is unscrewing dashpot plunger and holding it on edge of dashpot and pushing down hard while operating the throttle.
Float valve is operating without washer to raise fuel level.
Any non-standard parts that might be involved with the problem?
Nope.
Edited by Disco Dan, 11 January 2009 - 01:09 AM.
