Which Oil Should I Use?
Posted 11 January 2009 - 08:41 PM
"We understand what it takes to keep your car working just as it should. New Castrol Magnatec contains Intelligent Molecules for active and continuous protection, keeping your car at its peak for longer. Tested and approved to European Automobile Constutors Association (ACEA) and American Petroleum Institute (API) specifications.
Castrol Magnatec 15W-40 A3/B3 is suitable for use in automotive engines including turbocharged and intercooled diesel engines where the manufacturer recommends ACEA A3/B3 or API SL/CF 15W-40 oils. Approved to Volkswagen and Mercedes Benz specifications. ACEA A3/B3, API SL/CF, MB 229.1, W 505 00"
OK, so what makes a classic oil any better than an oil like the above? Also, just had a quick skank around on the net and I am getting the impression that the A3 is a petrol based standard, and the B3 is a Diesel standard. Can anybody shed any more light on this??
Andy
Posted 11 January 2009 - 08:45 PM
it's up to you what oil you use, but the best protection for a Mini is 20W/50 classic oil from Duckhams, Penrite, Millers Transverse M or even that classic oil that Halfords stock with a picture of a Mini on it's tin.
My Mini is a 1990 model and I ordered Duckhams Q Classic 20W/50 off the net as I was having problems getting any locally.
Oh and my owner's handbook tells me that I should be using 10W/40 oil, but that was just because Rover were using the same oil for all it's models regardless and they didn't want to recommend an oil for older types cars when they were still making Minis.
Just look at the recommended service intervals they quoted on the later Mini models and a service every 12,000 miles just isn't good enough for the Mini. It needs a service every 6,000 miles at the very least. I tend to do mine every 3,000 miles which equates to about 6 month intervals for me.
Edited by taffy1967, 11 January 2009 - 08:49 PM.
Posted 11 January 2009 - 08:52 PM
http://www.4wheelpla...p-25000264.html
As I mentioned in this thread: -
http://www.theminifo...amp;hl=Duckhams
Posted 11 January 2009 - 09:13 PM
Taffy,This is where I got mine from: -
Thanks for the in depth reply. Hope you didn't think I was ignoring your coments on my last post, I just thought that I would find out what the general consesus was. What you have pointed out (engine and gearbox etc) makes sense. Appreciate the feedback.
Andy
Posted 11 January 2009 - 10:26 PM
Posted 12 January 2009 - 09:32 PM
Andy
No worries and as you own a MKII Mini Cooper S you might want to join and register it on the Mini Cooper Register forum. I'm sure they'd agree with me on the choice of engine oil too.
Posted 12 January 2009 - 09:57 PM
Did a bit of searching and going off that chart I would think a better oil would be 15w40 mineral oil.
20/50 is only rated there to 0 degrees.
Posted 12 January 2009 - 10:35 PM
midget manual says use the same in both, but was wondering if i might do better with gearbox oil in gearbox and a more enginey biased oil in the engine
don't suppose it makes much difference, but would be interesting to know thoughts
Posted 13 January 2009 - 12:11 AM
what if the engine oil is separate from the gearbox oil?
If you have managed this then yes, a thinner engine oil would benefit, and it would also benefit from less foreign particles in the oil. However why change a design that worked for 50 years - just drive and maintain well!
Posted 13 January 2009 - 10:21 PM
Plus the Minis gearbox gives the oil one hell of a pounding before the engine sees any too, so I doubt a cold morning start is going to cause any problems.
Posted 13 January 2009 - 10:25 PM
But it's never run so well since I started using Duckhams Q Classic 20W/50 a few years back.
