Help Me Nd My Min Spike
5 replies to this topic
#1 tomtomtom
tomtomtom
    Just On Tickover
  • 9 posts
Posted 13 January 2009 - 03:21 PM
>_< Hi i have had my mini (spike) for about three months, it has alredy had a tough life considering it was only made in 1996, last week i had no battery in the morning after driving the day before so the natural asumption was that i had no battery...so i then bumped started the car with success and drove the long way towards work so the battery was charged. several hours later when work was boringly done i couldn't start my car.....again the classic was bumped started. however every morning when i either go to college or work there is again no battery, this is a new battery by the way.
Today was different however as i had be drinking the night before i stupidly put the live cable on the earth side on my battery, smoke then began to come out of my bonnet and the horn came on, noticing that this should never happen i checked the leads and noticed my mistake. i then tried to start my car the correct way. SUCCESS!!!!. However the car then would cut out whenever the cables were taken off, this was stopped when i reved the car. Should i just drive a while so some battery can get in?
The only thing is i don;t want make more damage by driving it, or should i try again when i hasve a new battery or will i need to check the elctrics? :P
Edited by tomtomtom, 13 January 2009 - 03:55 PM.
#2 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 13 January 2009 - 04:03 PM
Sounds like you've fried your alternator, and sounds like it wasn't working well in the first place either.
#3 tuktuk
tuktuk
  • 1,231 posts
Posted 13 January 2009 - 04:07 PM
get it running with a new battery and measure the voltage across the terminals... if youre alternator is working (which as retro10's said it sounds like its not) you would get 14+V >_<
#4 mrsam
mrsam
  • 192 posts
Posted 13 January 2009 - 04:55 PM
Im Taking Its An Spi.
When You Say You To The Cables Off Was That When You Were Jumping The Car ?
If You Disconnect The Battery Whilst The Engine Is Running It Wouldnt Run, Due To The ECU needing The Power. I Didnt Mean To State The Obvious Lol
But Yeh Sounds Like You Have Fried Somthing Along The Lines
#5 tomtomtom
tomtomtom
    Just On Tickover
  • 9 posts
Posted 14 January 2009 - 10:54 AM
cool yeah um, i have found another battery and charged that and will put that in today, i have also taken the alternator of my old 1982 mini to see of that woill fit in, so hopefully my mini dream will be back on the road.
thanks guys
#6 tomtomtom
tomtomtom
    Just On Tickover
  • 9 posts
Posted 20 January 2009 - 01:40 PM
Thanks guys, i have tried the alternator and have found that the problem is the electrical wires connecting the battery to the alternator and my local mini spec is coming tommorw to fix it, thanks again.
