Quite often when I stop at a junction and depress the clutch the revs on my car fly up to over 3000 and stay that high. The only way I can get the revs to lower down again is my raising the clutch almost to biting point. They stay high when I am in neutral.
Also, if I attempt to pull away quickly, eg at a roundabout/junction and so lift up my clutch and put my foot down on the gas quite quickly my mini hesitates and sort of stutters out. It doesn't recover unless I lift my foot up and then down on the throttle again. When this happens the mini also makes a strange noise, hard to describe but a sort of groaning.
When the revs aren't flying up really high and I am sat at idle the mini very rarely idles below about 1300 rpm.
I've had the stepper motor taken out and everything flushed through and cleaned by a local garage. This didn't change a thing. Someone has also had a quick look at the throttle cable to check it isn't getting stuck and they seem to think it's fine.
Took it to be diagnosed and faults were found with coolant temp and also air temp sensors. These were both replaced and the car ran great for all of two days until the above problems came back again. Took it back to be re-diagnosed and no faults were found? yet after being on the diag machine it drove perfectly for a day then the problems came back. (as they did when just the fault codes were cleared on the original test).
This leads me to believe I still have an issue with a sensor.
Can anyone help? I am getting fed up because currently driving through town every day is extremely hard work, I am having to use my clutch at the very last minute when stopping, hold my car at biting point when sat in a queue (I can hardly ever just sit in neutral due to the high revs) and nurse my car away from junctions.
edit:forgot to say its an mpi, low miles but was sat around for last two years. Have changed spark plugs since had it but thats it. Due for service this month.
Edited by shedonwheels, 15 January 2009 - 08:47 PM.
