Drive Shafts / Gearbox Help Me
9 replies to this topic
#1 mini_mob
mini_mob
  • 65 posts
  • Local Club: wot no brakes
Posted 16 January 2009 - 08:07 PM
hello ther i have a 1984 mini 25 998cc engine
i was driving round a roundabout when a knocking noies started i fort it was wheels catching or something so i pulled off the round about and tryed to pull off but i just got a slight pull and lots off knocking noises and crunching i pushed her off the road and now is all i can get is a spining whirring noies
culd this be drive shafts gearbox cluch any one no i had a quick look but everything looks right
the only non standard parts are 7.5 disks
please help
martin
#2 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 16 January 2009 - 08:26 PM
could be:
broken outer CV,
diff pin or
drop gears.
Paul
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 January 2009 - 08:55 PM
Or the splines on the pot to driveshaft joint... seen that one before too...
Best option is to get it up on stands and have a butchers.
#4 mini_mob
mini_mob
  • 65 posts
Posted 16 January 2009 - 08:59 PM
thanks lads ill get it in the air and have a look tomora do you think its going to be a big job
thanks agane
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 January 2009 - 09:13 PM
All depends what it is...
best thing to do is, with the assistance of someone, get it in the air, stick it in gear, one hold one wheel and try and turn the other... see what, if any, parts move and what parts don't.
#6 mini_mob
mini_mob
  • 65 posts
Posted 16 January 2009 - 09:25 PM
ok mate il try that first thingin the morning thanks agane
#7 Brigbeale
Brigbeale
  • 287 posts
  • Local Club: Bournemouth Mini Club
Posted 16 January 2009 - 10:57 PM
This should be with the engine switched off as a safety precaution!!!!
Initially with it in the air and in gear - it doesn't matter which - rotate one wheel and see if the other turns the opposite direction. i.e. if you rotate the left front in a forward direction, the right front shoul turn in a reverse direction.
If the other wheel doesn't spin, try pushing the driveshaft towards the centre of the car and if necessary turning it a little. I had a car which drove ok for months and then when I got the car out of a lockup garage and turned hard right, the left hand driveshaft inner joint popped itself out just enough to disengage the splined from the diff. A quick shove and it was back in. Neighbour's Rover 400 did the same because he worked on it and forgot to put the circlip back on thinking the suspension would hold it in place. He didn't realize the driveshaft was able to move in and out slightly.
#8 mini_mob
mini_mob
  • 65 posts
Posted 16 January 2009 - 11:03 PM
ok mate thanks for that if it is that what do i do to get it back in and hold it in
thanks
#9 Brigbeale
Brigbeale
  • 287 posts
Posted 17 January 2009 - 08:59 AM
thanks
If it is that, then it would more than likely need a new circlip on the inner joint splines where it enters the differential unit.
Basically it is a circular piece of steel 'wire' which compresses as it passes through the diff as you push it in (it may need some assistance to centre it and guide it in). Once the driveshaft is fully in, the clip returns to it's normal shape and keeps the inner driveshaft joint locked in place.
Usually, to get them out, you require the inner joint removal tool (which basically is a flat plate with a large cutout to suit the shape of the joint and it has a small block welded to the back). You put this on with the small blaock towards the gearbox and hit the flat plate end with a hammer. This then pops the 'unlocks' the circlip and allows the joint to be removed.
A long prybar can be used but may cause damage to the gearbox casing if care is not taken.
The circlip sits in a groove near the end of the inner cv joint.
They don't cost much and it is usually recommended to change them when the joints are removed.
Edited by Brigbeale, 17 January 2009 - 09:01 AM.
#10 tog77
tog77
  • 161 posts
  • Local Club: maun mini's
Posted 08 February 2009 - 03:22 PM
sounds like the mainshaft nut has backed off allowing the diff drive wheel gear to con off the spline..iv'e had this happen twice in the past
