Coil Over Spring Rates
4 replies to this topic
#1 cortinamini
cortinamini
    Starting My Mini Up
  • 4 posts
Posted 17 January 2009 - 07:37 PM
Hello
I've just brought some AVO aluminum coil over front shock which are not fitted with springs, can anyone give nme some advise on nwhat sort of lb spring would work best for a road/track day mini, the front corners are 125 kg.
Thanks Tom
#2 01smartc
01smartc
  • 1,412 posts
Posted 17 January 2009 - 07:42 PM
Just as a guidline my hillclimb race mini has 350lbs on the front and 125lbs on the back
Probs not quite the same for you on the road, might need less front and more back
Chris
#3 cortinamini
cortinamini
    Starting My Mini Up
  • 4 posts
Posted 18 January 2009 - 12:15 PM
thanks for that, I will ring avo on monday and see what they say.
#4 01smartc
01smartc
  • 1,412 posts
Posted 18 January 2009 - 03:12 PM
Just a warning if you ring AVO they wont tell you what spring rate to use....when i rang they said its their policy not to suggest spring rates.... i suppose so they can't be blamed for anything.
#5 cortinamini
cortinamini
    Starting My Mini Up
  • 4 posts
Posted 18 January 2009 - 10:13 PM
anybody fitted any springs to a road car?
