Rear Wheel Studs
5 replies to this topic
#1 Ty4815162342
Ty4815162342
  • 243 posts
Posted 19 January 2009 - 01:03 PM
hi, hopefully a simple question for one of you.
I'm fitting 13x6's on the mini and i needed to spacer out the rear wheels as they rubbed against the radius arms. I've got the 3/8" spacers and i thought i could get away without the need to buy the longer studs. But the nuts wouldn't tighten- so i now need longer studs.
So, what length do i need, bearing in mind i have the spacered minifins?
is it the 65mm? or 85mm?
cheers
#2 Ty4815162342
Ty4815162342
  • 243 posts
Posted 19 January 2009 - 03:31 PM
can anyone help here?
#3 nicksuth
nicksuth
  • 1,631 posts
Posted 19 January 2009 - 03:40 PM
Knock one out, measure it and then add on the extra bit you need for the nut? Here's a 60 and an 80
[attachment=78372:DSC00308.JPG]
Edited by nicksuth, 19 January 2009 - 03:43 PM.
#4 Ty4815162342
Ty4815162342
  • 243 posts
Posted 19 January 2009 - 06:22 PM
cheers, but i don't really have the time and space to knock one out at the moment. So can anyone else advise me here?
-Or does anyone know the standard stud length of a 1990 mini- then that would also help?
#5 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 20 January 2009 - 07:46 AM
Sportspack wheels = 13x6
Standard sportspack stud (58mm);
RLJ100060 .
Same length, but has less corser splines for fitting semi worn holes;
ENJO-1039.
HTH
Ryan
#6 Ty4815162342
Ty4815162342
  • 243 posts
Posted 20 January 2009 - 12:11 PM
RLJ100060 ..
ENJO-1039..
HTH
Ryan
cheers
