Ok now im really peed off.............. As you all know i completed Nini last week and since i changed the carb on her she is very very quick and out does Grover no problem !! Grover currently has a 1275 metro engine were Nini has a 1275 Mg metro lump and the difference is shocking !!! So because Nini belongs to my other half and is faster....... Im seriously thinking of 1 either going for a mg turbo lump or 2 putting a set of 1.5 rolling rockers on ? both will cost the same amount but do i really want all the work of a engine change and whats involved with fitting a turbo lump ? Other than the usual bits !!
Mg metro turbo conversion
Guest_Beno_*
, Aug 07 2005 06:45 PM
6 replies to this topic
Guest_Beno_*
Posted 07 August 2005 - 06:45 PM
Posted 07 August 2005 - 08:01 PM
Turbo conversions require the bulkhead to be cut and a box welded in. The heater then has to be mounted a bit further forward. You'll need all the bits off the metro like the fuel pump, fuel regulator and of course the turbo unit and engine.
Spend the money on a Nitrous kit instead. It'll fit your standard engine and can be set up to be switched on at full throttle, saves a bit of fuel :cheese:
Guest_Beno_*
Posted 08 August 2005 - 08:08 AM
So what is involed in fitting a Nitrous kit ????
Posted 08 August 2005 - 08:22 AM
ahhh beno beno beno....
send her on holiday mate, then swap the engine, when there out swap the colours if there painted, then youle get away with it! how easy was that?
i wouldnt use nos, imo its a waste of money and youle blow your engine into a million peices unless youve spent loads on it, i would turbo it
Posted 08 August 2005 - 11:48 AM
You must be planning on getting some mighty expensive 1.5s if you can do a turbo conversion for the same price.
Best way to make your car go faster is by getting a better cylinder head and cam.
I bought an MG metro cam recently for £15 and you could get a decent head for say a couple of hundred squid.
Wil
Wil
Posted 08 August 2005 - 05:54 PM
A bit of plumbing, mount a cylinder in the boot, couple of solenoids in the engine bay, a couple of nozzles fitted into the manifold, fix an activation switch on the throttle at full throttle results in 25 to 45 bhp instantly when you mash your foot to the floor, no lagSo what is involed in fitting a Nitrous kit ????
Have a look at this link to find out about nitrous, this site helps you build a DIY system but if you are not technical and don't want to melt your engine then a purpose built system can be bought from MOSS Europe, though they don't list a price.
http://www.diy-nitrous.fsnet.co.uk/
http://www.moss-euro...icMini_UKCM-223
Guest_Beno_*
Posted 08 August 2005 - 06:24 PM
I like the idea of the moss system ill enquire on price tomorrow !!!
In the mean time ive gotta fix this bloody oil leak its driving me nutts
Ive changed both driveshaft oil seals the crank shaft oil seal and its still leaking
Ive just been out to have another look and found a small crack in the driveshaft pot casing but even still i really cant imagine this to through out so much oil ! I mean the entire underneath of the car is caked in oil right down to the rear silencer i just dont know what else to tryu other than replacing the pot casing ! Any idea's would be great .
