Weird Noises From Gear Stick Region
13 replies to this topic
#1 stormintrooper
stormintrooper
  • 2,072 posts
Posted 19 January 2009 - 11:30 PM
along time ago when the engine was running and still in the car >_< whenever i revved the engine i would get this horrid noise coming from the region of the gear stick
now i panicked at first thinking something was wrong with gear box but it would happen when in neutral and clutch pedal pushed down all the way
now when removing the engine i did noticed the bracke that held the bottom of the LCB to the gearbox was a little loose
im hoping someone can tell me it was this vibrating harshly from reving that caused the noise but if not has anyone got any other sugestions...obviously i cant test things out as engine is not in car
but all ideas are welcome
thankyou in advance
p.s. i was going to try the search feature but for the life of me cudnt think what to type in it
"weird noises under reving" didnt strike me as working :dontgetit:
#2 stormintrooper
stormintrooper
  • 2,072 posts
Posted 20 January 2009 - 12:09 PM
i know this isnt the most urgeant of things but can anyone put my mind at rest even if it could be bad news?
thankyou
#3 RowenBlaineSkinley
RowenBlaineSkinley
  • 641 posts
Posted 20 January 2009 - 12:30 PM
could be the engine steady
is it an mpi?
Edited by RowenBlaineSkinley, 20 January 2009 - 12:30 PM.
#4 stormintrooper
stormintrooper
  • 2,072 posts
Posted 20 January 2009 - 12:46 PM
noooo its a standard 998 carb
but as i said why would the nmoise be coming from the region of the gear stick
#5 RowenBlaineSkinley
RowenBlaineSkinley
  • 641 posts
Posted 20 January 2009 - 12:49 PM
well the engine is connected to the gear box, if the engine moves then the gear stick will
#6 mike.
mike.
  • 6,176 posts
Posted 20 January 2009 - 01:03 PM
Seatbelt bolts hitting the exhaust. This is what i get when i dont use a washer on the seatbelt clip bolt - The bolt screws in far enough to touch on the exhaust and rattle under certain revs.
#7 stormintrooper
stormintrooper
  • 2,072 posts
Posted 20 January 2009 - 06:29 PM
hmm...sounds plausable...however this noise happened out of nowhere and i had not tampered with seat belts prior
am i right in hoping its nothing to do with the gear box seing as it made this noise in neutral and with clutch pushed to the floor
#8 rosco454
rosco454
  • 908 posts
Posted 20 January 2009 - 10:35 PM
It could be the centre exhaust mount gone as this gives a knock/rattle from that area depending on what the exhaust hits.
#9 stormintrooper
stormintrooper
  • 2,072 posts
Posted 20 January 2009 - 10:39 PM
it was a bit loose when i removed the engine etc
im just hoping someone can reasure me from my worries my gearbox is knackered
#10 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 20 January 2009 - 10:42 PM
Check the engine for movement give it a good rock and get someone to rev it while you look under the bonnet. Also get underneath and check all the exhaust mountings are fine.
Once you've excluded those things it gives us a better indication of whats going on.
Edited by DannyTip, 20 January 2009 - 10:43 PM.
#11 sprintmini
sprintmini
  • 316 posts
Posted 20 January 2009 - 11:18 PM
I think youhave already mentioned the problem.
If the exhaust bracket was loose then once the engine was revved it would cause the bracket to vibrate.
Tighten the bracket when the engine is refitted see if that helps.
#12 stormintrooper
stormintrooper
  • 2,072 posts
Posted 20 January 2009 - 11:26 PM
cheers..i did think this but it had the horrib noise that sounded half way between a vibration to a grinding but im glad you mostly think its the exhaust
thankyou all and will let you know once the engine has been put back in..may have it serviced whilst out
#13 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 21 January 2009 - 09:05 AM
It could be those Cotton Reel Rubbers that attach the Rod change box to the Shell, they could be a little shot and the engines vibration is is going into the linkage and not being absorbed by the rubbers.
#14 rosco454
rosco454
  • 908 posts
Posted 21 January 2009 - 10:57 AM
For what it would cost and while the engine is out its worthwhile changing at least the exhaust mount and as said above the selector mounts,you might want to change the steady bushes etc as well just to firm everything up.
