What Generator To Run A Welder
10 replies to this topic
#1 scrumpymini
scrumpymini
  • 380 posts
  • Local Club: NSMOC
Posted 21 January 2009 - 05:44 PM
Hello all i have just got one of these to try my hand at welding
http://www.sip-group...atalogue/14.pdf
The problem is some of the welding i need to do is in a garage that has no power, has anyone else hired or purchased a generator that you can use for running a welder, 2.0kw generators do not seem to bad to buy new or like this one on fleabay
http://cgi.ebay.co.u...hlink:middle:uk
but will this be OK.
Cheers for any help.
Steve.
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 21 January 2009 - 06:22 PM
230v 13 amp supply - Use from standard
thats 3.25 kva you genny is 2kva
#3 scrumpymini
scrumpymini
  • 380 posts
  • Local Club: NSMOC
Posted 21 January 2009 - 06:27 PM
So i need a genny that is rated at 3.25kva or above then ?
Ta.
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 21 January 2009 - 06:45 PM
yes
but i don't know if a welder has a surge on start up
#5 scrumpymini
scrumpymini
  • 380 posts
  • Local Club: NSMOC
Posted 21 January 2009 - 06:55 PM
yes
Think i might hire one of these when i am ready for some welding,
http://www.hss.com/g...ank-Petrol.html
i will just have to cut out the rust and make up the patch panels first so i do not have to hire it fo to long, man wish i had a bloody garage at my house.
Edited by scrumpymini, 21 January 2009 - 06:55 PM.
#6 dave21478
dave21478
  • 639 posts
Posted 21 January 2009 - 07:06 PM
I have a 4kva genny, and it can just run my mig welder. Its harder to weld though, and the welds are noticeably poorer, plus it has a habit of stalling the genny every now and then. I use it for fixing up gate posts etc. (by the way, the arc welder is noticeably better running from the genny) but wouldnt even consider doing bodywork with it.
To say nothing of the incredibly annoying noise - it really gets tedious very quickly, and if there are houses nearby, the residents WILL hate you.
It would be much, much better if you could run power to the garage - even if it takes a couple of extension reels, from your own house or from a neighbouring house in return for a few beers/money etc.
Edited by dave21478, 21 January 2009 - 07:08 PM.
#7 dave21478
dave21478
  • 639 posts
Posted 21 January 2009 - 07:12 PM
Oh, and if you do go the generator route, watch the ratings carefully. The quoted power output is normlly its PEAK power, which can be sustained for short periods, you need to check that its CONTINUOUS power, which is often as much as a third lower, is up to your needs.
Edited by dave21478, 21 January 2009 - 07:13 PM.
#8 daemonchild
daemonchild
  • 2,341 posts
  • Local Club: Unknown
Posted 21 January 2009 - 07:24 PM
Good answers- this solves a quandary I was in too.
I think the beer money priced electricity from a neighbouring house may be the plan...
#9 scrumpymini
scrumpymini
  • 380 posts
  • Local Club: NSMOC
Posted 21 January 2009 - 08:16 PM
Well my garage is over a mile from my house so no way can i run a lead to it, i only need to weld on two small patches on the sills, a section on the boot floor and the rear valence so it is only for a very short time so i hope not to make to much noise, i have a small 950w 2 stroke at the garage which i run my power tool off and that is very quite just wish the grinder was the same, i only do work at times when i hope people wont mind to much and only for short periods of time.
I guess i could move house but with the amount that would cost i could buy a bloody good mini or two.
#10 Burnard
Burnard
  • 3,350 posts
Posted 22 January 2009 - 12:25 AM
http://www.machinema...site-generators
That should handle the power needs, apears to be 4.5kva continuous and 5.5kva pea. But I'm not sure if it has the right sockets on it though.
Chris
Edited by Burnard, 22 January 2009 - 12:25 AM.
#11 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 22 January 2009 - 11:11 AM
Chris
Thats the one iv got and even though its the best i coul afford it still only just and i mean just runs my mini, and you can clearly see the weld quality is alot worse...
