Valve Clearances For 1380 With 1.5 Rockers
Posted 23 January 2009 - 07:34 PM
Not sure if snyone has asked this question before......
Does anyone out there know what the valve clearances are for a 1380 with 1.5 roller tip rockers??
Posted 23 January 2009 - 07:45 PM
Posted 23 January 2009 - 07:52 PM
What cam are you running? but i would set them at 16 thou
I'm using an SW5-07 cam and stage 3 head....
I asked a friend who suggested 18thou, but not 100% certain
Posted 23 January 2009 - 07:55 PM
Posted 23 January 2009 - 08:09 PM
Posted 23 January 2009 - 08:12 PM
paul
Posted 23 January 2009 - 08:20 PM
Looks like 16 to 17 thou is the general consensus, looks like i'm going to have an interesting saturday adjusting the valves
Posted 23 January 2009 - 08:37 PM
Posted 23 January 2009 - 08:40 PM
Edited by AzMaN, 23 January 2009 - 08:40 PM.
Posted 24 January 2009 - 05:08 PM
Oh top tip for anyone else wondering how to check each valve gap.....stick the car in 4th gear, jack one of the wheels up off the ground (taking the appropriate safety cautions obviously). With the one wheel off the ground, rotate it and this will cycle the engine allowing each tappet to be adjusted and checked individually.
However, i think this method will only work for car without a limited slip diff......
Posted 24 January 2009 - 06:23 PM
Spoke the garage who built me engine for me this morning...they recommended 16 thou. So wipped the rocker cover off and checked/adjusted the clearances where necessary.
I stick it in 4th and roll it back and forth... builds up those thigh and calf muscles! LOL!
