Edited by meetthespeakers, 26 January 2009 - 04:58 PM.
Posted 26 January 2009 - 02:31 PM
Posted 26 January 2009 - 03:12 PM
Posted 26 January 2009 - 03:46 PM
Hi there,
Unfortunately you may need to take the arches off the front and start again. Unless the bodywork's been previously modified you'll need to cut away part of the wing/body on the front to prevent the wheels from rubbing when fitting wheels 6x12 +. I'm sure someone else will be able to help you with the technical side as I got a mini specialist to do mine.
Hi-lo's will allow you to adjust the ride height of the car so that it sits nicely above the arches. Easy to adjust as well, you simply take the wheel off, turn the nut a couple of times and hey presto!
Hope this helps.
Courtney
Posted 26 January 2009 - 04:29 PM
Hi there,
Hope this helps.
Courtney
I already trimmed the front arches per Mini Spares templates. However it clears the metal arch part fine, it's the outer lip of the sportspack arch it doesn't clear currently as you can see in the picture. I was told that you can use the adjustable tie rod to push the wheel back. Also I have hi-lo's fitted as well that I was going to lower it with possibly 1-2 inches.
Posted 26 January 2009 - 04:32 PM
Posted 26 January 2009 - 04:33 PM
Did you buy the arches from Minispares?? I think you'll find that the templates are specifically for the genuine sports pack arches.
Posted 26 January 2009 - 04:57 PM
Posted 27 January 2009 - 07:16 PM
Posted 27 January 2009 - 07:37 PM
sorry to here about the arches but you have a nice mini how much where your spots and where did you get them
thanks Dan
Posted 27 January 2009 - 08:06 PM
Posted 27 January 2009 - 08:59 PM
have the front knuckle joints been replaced, this should bring the wheel back a little.adjusting the tie rod might knock out other things and make the handling worse.
Posted 28 January 2009 - 01:45 PM
Posted 28 January 2009 - 02:07 PM
i had the same problem that you have now the little lip at the front catches and u will find that the bumper indentation with also rub, what i did was use a stanley knife and cut the arch away bit by bit untill it was clearing then i used a sander to smooth the arch to make it blend in with the rest.
i had to cut a fair bit off on both sides, i will be changing mine to fiberglass soon as the rubber versions change shape in different weather
Posted 29 January 2009 - 02:02 PM
Posted 30 January 2009 - 02:46 PM
