Panel Replacement Sequence
Posted 27 January 2009 - 12:08 AM
I have searched the forum for a many hours over the past few days. Looking at peoples restoration projects etc and reading posts in the bodywork sections. Still i have some questions as they pertain to my project and the sequence in which i should do the replacement panels.
Today i have my mini stripped off all parts and mounted on a spit. This weekend i am hoping to remove the front wings, front half of inner fenders and front nose panel. Putting on a flip front, so i thought i would get these panels off now. Also this weekend i am going to brace the shell as most do between the doors and across the inside of the car.
Now i have/want to replace the floor, inner/outer sills, door steps, a panels, inner fenders (from shock mounts back), door hinge panel, stiffener panels, and scuttle. For starters.
In what sequence would i be best to do all of those in to maintain panel alignment and structural integrity.
I am thinking that if i have the brace bars fitting i cannot replace the door hinge pieces because they will be welded to the brace bars. So i would assume maybe the floors and sills first then remove brace bars and do all hinge panels, inner fender, and a panel.
Thanks, Paul
Posted 27 January 2009 - 07:39 PM
Hey,
Thanks, Paul
i am doing the floors,sills,inner sills,doorsteps,inner wings,outer wings,scuttle,front valance aswell so i would also like to know which are the priorities !
cheers
Posted 27 January 2009 - 09:31 PM
Edited by robtheplod, 27 January 2009 - 09:31 PM.
Posted 27 January 2009 - 10:40 PM
There must be a logical way to do it. I am sure someone wise could let us in on the way to attack it.
Posted 27 January 2009 - 10:42 PM
Posted 27 January 2009 - 10:52 PM
I want to replace the entire floor. I think i will end up doing each side (floor front to rear, inner sill, outer sill, door step) one at a time. Then move onto door post panels, flitch's, and a panels.
Do this sound like a good plan? This way i should still be able to get the door on (mounted by hinges) for checking gaps while doing sills and door step. then when i do door post, flitchs, and a panel i will clamp the door in place and use the hinges on the door, and door itself for aligning.
Thanks, Paul
Posted 27 January 2009 - 10:59 PM
Posted 27 January 2009 - 11:09 PM
im replacing just the front floor pans and not the whole floor ( lucky me lol )
then i gotta replace all this:
which is the order to do the car in? id say:
inner sills
sills
floors
scuttle
inner wings
outer wings
front valance?
when replacing the front valance and matching it to the wings should i fit and bolt it to the subframe first?
also i dont need to worry about the gaps to much as only weling a doorskin to the body ( its an autograss car so needs to be as light as possible)
cheers
Edited by autograss, 27 January 2009 - 11:12 PM.
Posted 27 January 2009 - 11:13 PM
in my mind the logical order would be:
(floor pan)
innersils
step panels
jacking points
outer sils
(A-Panels)
it just seems a logical order in my mind seeing how they are attached, and what you would need to be able to get to in order to fit the next part.
just work it out, what comes off first, should go back on last, unless it has fallen off already, then work out when you would have taken it off.
Chris
Posted 27 January 2009 - 11:17 PM
cheers
Posted 28 January 2009 - 07:06 PM
