Rear Swingarm Measurements
1 reply to this topic
#1 Wombat
Wombat
  • 13 posts
Posted 27 January 2009 - 03:59 AM
How can you determine if the swing arm has been bent from hitting the gutter? I realise there are measurements to check the sub frame alignments but what about the arm itself?
David L
Edited by Wombat, 27 January 2009 - 04:00 AM.
#2 rozzer1275
rozzer1275
  • 439 posts
  • Local Club: ah
Posted 27 January 2009 - 09:35 AM
If your talking about the rear radius arm i think the hub should be 90deg from the pin any small misalignements can be taken out by adjuster brackets or spacers under them, rear tracking and camber is all over the place on a mini any way (positive camber and toe in)
