Just a quick one
bought and fitted a electric fan, it runs and works when just powering it but dosnt/wont work when using the temp gauge that fits into the rad .. i cant get it .... anyone had any experience with it???
Kenlowe Electric Fan (not Working) Help?
Elfin
, Jan 27 2009 08:53 PM
6 replies to this topic
Posted 27 January 2009 - 08:53 PM
Posted 27 January 2009 - 09:01 PM
It only comes on when its needed - Like sitting in traffic on a sunny day. Maybe the engines not getting hot enough?
Posted 27 January 2009 - 09:13 PM
yeah i let it warm right up about 80-90c
Posted 27 January 2009 - 10:31 PM
where have you fitted the thermostat? as mine was fitted in through the bottom hose of the rad and always worked fine! although the thrmostsat switch has now broken so its constantly on unless i disconnect it under the bonnet!
matt
matt
Posted 27 January 2009 - 10:44 PM
if it has an adjustable thermocouple/control box id check if its set to cut in at the right temperature and the usual check the wiring to the relay and thermostat for a live feed etc....... ive fitted a few of these fans to landrovers and always been told to insert the thermocouple into the pipe which is at the top of the radiator.....
Posted 28 January 2009 - 01:19 PM
yeah mine goes in at the top, i have had the switch on cold and hot, i am thinking that if the thermostat bulb wasnt in the water it wouldnt give a hot reading so it wouldnt engage??
Posted 28 January 2009 - 01:32 PM
Could try putting the bulb in a pan of boiling water see if it kicks in.. least you'd be able to see if it actually works.
