Carb Needle
19 replies to this topic
#1 stormintrooper
stormintrooper
  • 2,072 posts
Posted 29 January 2009 - 10:09 PM
as said above is there anyway of knowing what needle i have in the carb? as im not sure what it will have atm as i have no history of the car and suspect the stage one was fitted prior but after hte bodge jobs the previous owner did around the rest of the mini i worry he may not have put the correct needle in, are there any ways of finding out?
#2 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,231 posts
  • Name: Simon Jackson
Posted 29 January 2009 - 10:14 PM
Remove dashpot, and take the needle out, each needle has a 3 digit code, eg AAU, ABC etc
#3 stormintrooper
stormintrooper
  • 2,072 posts
Posted 29 January 2009 - 10:19 PM
cheers..now before i make an arse out of myself the cone filters class as part of the stage one dont they?
#4 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,231 posts
Posted 29 January 2009 - 10:22 PM
Some peoples kits, yes
#5 stormintrooper
stormintrooper
  • 2,072 posts
Posted 29 January 2009 - 11:28 PM
what needle should i have as part of a stage one?
#6 lrostoke
lrostoke
  • 6,923 posts
Posted 30 January 2009 - 07:12 AM
There's a few that are suitable assuming its a 998...AAC is a bog standard needle for a bog standard car so if stage 1 you don't want it.
AAU , AAM , AAA and possibly ABY
If you put the needle codes into this site it will show you how the fueling works for each jet.
http://www.mintylamb.co.uk/suneedle/
#7 stormintrooper
stormintrooper
  • 2,072 posts
Posted 30 January 2009 - 10:00 AM
thats very good but i dont realy know what im ment to be looking for, will only be used to road use, and yes i would like fuel economy but at the same time want to keep some of the power acquired by the stage one, any sugestions?
#8 Pauly
Pauly
  • 4,213 posts
Posted 30 January 2009 - 11:22 AM
Got a k&n cone on mine and im running a AAM, seems spot on but its not been rolling roaded yet.
Paul.
#9 lrostoke
lrostoke
  • 6,923 posts
Posted 30 January 2009 - 11:25 AM
If you've got a cone filter, freeflow or lcb manifold then go for the AAM
But the point is all those needles will work, the AAM or AAA are normally most recommended for your application. And the AAU is you are running a stage 1 using a standard airbox with a K&N type filter.
Edited by lrostoke, 30 January 2009 - 11:26 AM.
#10 stormintrooper
stormintrooper
  • 2,072 posts
Posted 30 January 2009 - 01:19 PM
right well i just had a look at the needle, it said ABD
i have a cone filter and a LCB manifold
i know i will need henry on a rolling road but you sujest i get the AAM?
#11 lrostoke
lrostoke
  • 6,923 posts
Posted 30 January 2009 - 01:32 PM
ABD is almost an identical profile to the AAU, so worth trying it first, its only a 10 min swap to change them.
If you get a flat spot then a surge with that needle, then try the AAM or AAA
#12 stormintrooper
stormintrooper
  • 2,072 posts
Posted 30 January 2009 - 02:05 PM
ok then, well once everything is back together and engine back in the car (possibly after having it serviced) i will have him rolling roaded
#13 jaydee
jaydee
  • 8,565 posts
Posted 30 January 2009 - 02:10 PM
i've noticed some standard 998 come with AAP as standard needle and some others with AAC, but basically they have the same flow.
#14 lrostoke
lrostoke
  • 6,923 posts
Posted 30 January 2009 - 03:56 PM
according to that mintylamb website I linked to the AAP is a lot weaker than the AAC, should think it would really strangle even a standard car.
An AAP isn't any of the needles that Haynes lists for 998's of varios years
AC ,ADE , ABX ,AAC , GX and AAV all very similar profiles
#15 stormintrooper
stormintrooper
  • 2,072 posts
Posted 30 January 2009 - 04:03 PM
after looking at the needle chat is a line higer up in the mixture better?
