Year: 1990
This evening I was pulling out of a space and my steering column clicked on full lock. Thought it was weird so turned it back and the same thing. Was only a mile from home so slowly drove the car back home. I then checked all the steering track rods etc and they looked ok. I suspected a loose pinch bolt so checked that and sure enough when I torqued it and it took a fare bit before the wrench clicked at 16nm. Now my question is this I fitted a drop bracket when I rebuilt the car. Is it putting strain on the column and wearing the splines. It seems to be fine now. Do I need to remove the column to inspect it? Also thinking of removing the drop bracket as cannot remember if I rotated the rack to accommodate it during the rebuild. Also I have bucket seats so is the drop bracket necessary or is it just making my steering heavy. Advice please.
Zeroasylum
Any non-standard parts that might be involved with the problem?
Drop Bracket
Edited by zeroasylum, 29 January 2009 - 10:25 PM.
