Hi-lows. Do They Have To Be Tight Or Can There Be Some Play In Them
mrsam
, Jan 29 2009 11:17 PM
8 replies to this topic
Posted 29 January 2009 - 11:17 PM
I Got Hi-lows Fitted They Seem To High But I Want To Drop My Mini To The Deck Arches Permiting Is It Possible To Have Slightly Loose Hi Lows or Are They Best Left Fixed Tight.
Posted 29 January 2009 - 11:24 PM
hi when using hi-los i believe if u want to drop (sit it on its ass) lol for the rear you have to use shorter shocks as youll find that if u lower to much on standard shocks when u jack the car up the hi-lo and rubbercone falls out the sub frame, i seen a lowered shock set brand new at bingley hall the other day for little money, cheers
hope this helps,
Posted 29 January 2009 - 11:27 PM
you should get stiffer 'sports' dampers with hi-lo's fitted. or ideally adjustable shocks.
not sure what the original question is asking though
Posted 29 January 2009 - 11:36 PM
ah awsome thanks, so i need some new ajustable shocks
sweet thanks
Posted 29 January 2009 - 11:52 PM
well i fitted hilows at the rear today and all round Gaz adjustables they are kol if you want it on its ass it wont work
i tried i had it set up stiff but it rubs the arches both sides im just letting my shocks settle then i can lower her down again other wise they do it for you after a few 100 miles so will let you know if you like
Dan
Dan
Posted 30 January 2009 - 01:47 AM
Can you rephrase the question? It sounds like you are planning to make your Mini critically unsafe, the suspension should not be loose. I don't fully understand what you're asking though.
Posted 30 January 2009 - 05:11 AM
Im guessing your suspention is loose when jacked up not when its on the ground.
Mine is the same i have adjustable spax shocks, its fine when on the floor but when you jack it up the hi lo will become loose.
Posted 30 January 2009 - 05:13 AM
How do they ride? I just picked up the same setup.
Posted 30 January 2009 - 08:37 AM
Yeah when mines jacked up the hi-lo has slight play in it - I aked about it when i first discovered this and its fine apparently.
