Drive Flanges
7 replies to this topic
#1 jwb_moto
jwb_moto
  • 1,387 posts
  • Local Club: PMOC
Posted 30 January 2009 - 03:54 PM
What material are the standard 8.4" disk size drive flanges made of?
Im fitting minisports 7.9 vented which uses M10 capscrews to attach the disk to the drive flange but im having a hard time drilling the holes out to 10mm.
#2 Southy
Southy
  • 1,579 posts
  • Local Club: Oldham and Distrcit Mini Club
Posted 30 January 2009 - 04:11 PM
The material the flanges are made out of are EN24 steel.
Best bet to drill them out to is by using a set of soft jaws in a vice clamp the flange in the vice and then using a cobalt drill on a fairly low speed.
#3 jwb_moto
jwb_moto
  • 1,387 posts
  • Local Club: PMOC
Posted 30 January 2009 - 04:13 PM
Cheers sounds like a job il do at work.
#4 Udo
Udo
  • 1,670 posts
Posted 30 January 2009 - 04:20 PM
Personally I would also use a pillar drill to try and keep things square
#5 rozzer1275
rozzer1275
  • 439 posts
  • Local Club: ah
Posted 30 January 2009 - 04:28 PM
sharp drill, low speed, load of oil.
the one you have had difficulty with, start it agian from the other side of the hole with a new drill.
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 30 January 2009 - 04:31 PM
Really silly question, but are you not meant to be using Metro flanges ?
#7 jwb_moto
jwb_moto
  • 1,387 posts
  • Local Club: PMOC
Posted 30 January 2009 - 04:57 PM
According to minisport for their alloy caliper brake kits you retain the standard drive flanges. I thought the same as you (GW) to start off with but Tom at minisport assures me they are just standard ones.
They had some built up with hubs, bearings, balljoints, cv joint etc.
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 30 January 2009 - 09:53 PM
Strange that. I'd agree with Guess Works. I don't think you can get the vented disc on without it hitting the steering arm if you fit it using a standard flange. The Metro flange gives the disc a different offset. If Mini Sport say use the normal flange though then they must be right, it's their product.
