Miss Fire? Spluttering? Timming Out? :s
7 replies to this topic
#1 jakson
jakson
  • 42 posts
Posted 30 January 2009 - 04:51 PM
i have a problem just started occuring last 2 days, spluters loads lost power idle's at barley 100 revs choke on or off but its quite bad now, i think it may be sumthink to do with exhaust seems to be leaking gasses from behind the air filter not sure if its inlet or outlet but will have a look on saturday.
also i have a little black pipe that comes from distributer and goes to the water pump then a pipe goes from water pump to carb and another pipe goes into passnger wing from water pump, but noticed the pipe that goes into wing has snapped at a T piece by the water pump could this be part of the problem?
here is pic of pipe not very clear tho
Attached File  mini_pipe1.JPG   1.37MB   14 downloads
#2 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 30 January 2009 - 10:03 PM
That's the vacuum pipes or charcoal canister pipe I believe and yes it would cause problems if it's broken.
#3 jakson
jakson
  • 42 posts
Posted 31 January 2009 - 12:11 AM
any idea where i can get a new pipe from?
just looked on ebay couldnt find any :)
#4 Ethel
  • 26,074 posts
Posted 31 January 2009 - 01:39 AM
Try looking on Moss Europe or Somerford's sites they have online parts catalogues with piccies.
The bit in the piccy is a thermostatic valve that controls the vacuum advance. I'm not sure it would make your engine run as badly as you describe. Start by checking the ignition components plugs. leads dizzy cap..points if it has them.
#5 jakson
jakson
  • 42 posts
Posted 31 January 2009 - 11:24 AM
ive recently changed rotor arm, dizzy cap, ht leads and plugs about 2-3months ago but ill have a look at them see what they look like
#6 jakson
jakson
  • 42 posts
Posted 31 January 2009 - 11:38 AM
rite ive checked dizzy cap looks fine, checked leads look ok and checked plugs black soot on the ends
#7 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 01 February 2009 - 01:31 AM
What about the contact breaker points and condenser? (Unless you have electronic ignition?)
#8 jakson
jakson
  • 42 posts
Posted 01 February 2009 - 04:07 PM
think its electronic, just has rotor arm behind dizzy cap
