Front Subframe Washers?
4 replies to this topic
#1 rusimir
rusimir
  • 129 posts
Posted 31 January 2009 - 03:31 PM
Hi!
Dose it better poot set on pic 1 or 2 (why)?? And is it better to set below bulkhead circle (pic 2) or clasic rubber pic 3?
And does it better to set clasic SUBFRAME MOUNTING FOR REAR OF THE FRONT FRAME with rubber pic 5 or like on pic 4???
Or just poot set like on pic 4!!!
  • Attached File  1.jpg   6.51K   1 downloads
  • Attached File  5.jpg   6.44K   1 downloads
  • Attached File  3.jpg   5.05K   1 downloads
  • Attached File  4.jpg   7.19K   2 downloads
  • Attached File  2.jpg   4.7K   1 downloads
#2 Asphalt
Asphalt
  • 2,173 posts
Posted 31 January 2009 - 03:37 PM
The rubber stuff standard for post '76 cars.
The alloy pieces in pic 1 and rear steel mounts (pic 4) give a solid mounted subframe.
It gives sort of more precise and direct steering.
Most people replace the front mounts ('behind' the grille) with solid mounts too.
I'm not a fan of that, as in my opinion the frontend needs to be allowed to move a bit to reduce stress.
Mind you: it is advisable to reinforce the floor if you use solid rear mounts (pic 4).
#3 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 31 January 2009 - 03:49 PM
solid top mounts are fantastic, leave the floor and front panel ones rubber and it will drive great and should not experiance floor cracking
dave
#4 mk1leg
mk1leg
  • 9,343 posts
Posted 31 January 2009 - 04:17 PM
Just go for solid top tower mounts and leave front teardrop and rear as rubber You only need solid all round when racing .................. :(
#5 rusimir
rusimir
  • 129 posts
Posted 01 February 2009 - 12:37 PM
Thanks guys!
And solid top tower mounts wouldn't crack bulkhead?? And between bulkhead and subframe is better to set washer like on pic 3 or circular like on pic 1 and 2, or that isn't essential!!!
Thanks again!
Regards
Edited by rusimir, 02 February 2009 - 10:22 AM.
