Whats the torque setting for the 4off bolts securing the drive flange to the disk? i cant seem to see it on the list pinned above (stickied)
Drive Flange Torque Setting
jwb_moto
, Jan 31 2009 04:46 PM
2 replies to this topic
Posted 31 January 2009 - 04:46 PM
Posted 31 January 2009 - 04:51 PM
Torque wrench settings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Nm lbf ft
Driveshaft retaining nut (disc brake models):
With multiple split pin holes in driveshaft . . . . . . . . . . . . . . . . . . . . . . 207 150
With single split pin hole in driveshaft . . . . . . . . . . . . . . . . . . . . . . . . 255 to 270 188 to 200
Brake caliper retaining bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . .. . . 52 38
Disc to hub flange . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 57 42
Master cylinder body outlet plugs . . . . . . . . . . . . . . . . . . . . . . . . . . . 39 28
Master cylinder pressure differential piston end plug . . . . . . . . . . . . . 45 33
Pressure differential warning actuator end plug . . . . . . . . . . . . . . . . . 35 26
Pressure differential warning actuator failure switch . . . . . . . . . . . . . . 19 14
Edited by L400RAS, 31 January 2009 - 04:53 PM.
Posted 31 January 2009 - 04:52 PM
cheers buddy
