Sva Test Is Changing
Posted 02 February 2009 - 04:43 PM
so heres a VOSA leaflet giving you some information .. its set to change over on the 31st March so may be worth looking at for anyone whos building a kit car etc.
http://www.ampar.com...IVA leaflet.pdf
and this too
http://www.transport...tionmanuals.htm
bamby
Posted 02 February 2009 - 04:59 PM
Posted 02 February 2009 - 05:04 PM
Posted 02 February 2009 - 05:17 PM
In this month's Practical Performance Car magazine they said that if you fitted a chevrolet LS1 engine to an old car such as a mk1 mini and didn't alter the brakes , suspension etc then the car wouldn't need the test but if you fitted coil-overs, chevrolet brakes etc to make it safer then the car would need to be put through this test. It would probably never pass though because it was designed so long before the original SVA test was brought in.
Posted 03 February 2009 - 02:37 AM
I can see why kits car have to go through it to get registered but what's to stop us just moding and driving?
Posted 03 February 2009 - 09:02 AM
The points system has long been changed, just the government websites have yet to be updated (on the ball as ever). Essentially what has replaced it is the same system only without the points. You have to keep something like 2 or 3 of the major components (bodyshell, chassis, engine, steering, suspension, etc), with one of them having to be the bodyshell.Has anyone read about the points sytem that decides whether your car needs this test? It's something like you can get 14 points maximum but need at least 9 or so to avoid the test. You get the points by keeping original parts of the car, so if you change the engine, radically alter the suspension, brakes etc ( E.G fitting coil-overs to a mini) you lose the points and if you lose too many your car has to be put throught this test which is very hard to pass.
Posted 03 February 2009 - 10:39 AM
As for the IVA/SVA differences, the changes arent massive. The main thing thats getting the bike-engine car owners in a knot is a mandatory reverse gear, although this can be overcome using an electric reverse with a starter motor turning the prop/diff in reverse at the touch of a button.
My main gripe is that for no apparent reason, the test fee has almost tripled, and from what I read, is now a completely unreasonable £500.
Edited by dave21478, 03 February 2009 - 10:40 AM.
Posted 03 February 2009 - 11:45 AM
I can't see it mentioned on any of the gov sites or have I missed it?
You can also download the Draft copy of the whole IVA as well.
Posted 03 February 2009 - 12:11 PM
Posted 03 February 2009 - 03:27 PM
Posted 03 February 2009 - 03:37 PM
Posted 03 February 2009 - 11:44 PM
This is most likely to effect Kit Cars that are mostly made from new parts and an old engine such as the Westfield cars. Although it is most probable to affect all kit cars on the whole. With regards to re-shelling a vehicle there are guidelines that are set out as to what you need to do to maintain the origional classification and registration etc. It doesn't however say that a year or so down the line you can't modify the car futher (ie adding coilovers(sp) etc
as i said before until its all signed and sealed theres not really anything can do. just watch this space as they say.
