Model: All
Year: All
Description of problem (please be as in depth as possible): Looking for advice to bench test an engine.
Good evening,
I'm looking for some advice/instruction on how to bench test an engine whilst it is out of the car. I only need to run the engine for a few mins to check everything is OK.
Could anyone give me a quick run down on what needs connecting, what kit I would need and any hints and tips.
Is it possible to run the engine for a few seconds without a carb? I've seen people spray starting fluid directly into the inlet manifold before now!
Many thanks in advance for your advice.
JSG
Engine Testing
JSG
, Feb 02 2009 10:19 PM
7 replies to this topic
Posted 02 February 2009 - 10:19 PM
Posted 02 February 2009 - 10:27 PM
You mean like this
pretty simple but I reckon you'll need the carb on..
I just got a long length of clear hose, connected to the carb fuel inlet, filled it with fuel, clear was better I could see how much was in it.
Jump leads off battery, negative connected direct to starter motor solenoid housing.
then a wire from positive on the battery to positive on the coil
negative on coil goes to dizzy.
then to start I just touched the jump leads postive onto the battery terminal of the solenoid and made sure it also touched the solenoid energising terminal at same time .
fettled carb at same time.
Edited by lrostoke, 02 February 2009 - 10:28 PM.
Posted 02 February 2009 - 10:29 PM
Thanks for the reply.
A fellow Stokey eh
Cheers for the info!
JSG
A fellow Stokey eh
JSG
Posted 02 February 2009 - 10:31 PM
Castle, but saves people getting confused with up North
Ahh I see, common mistake
JSG
JSG
Posted 02 February 2009 - 10:40 PM
Just point out the obvious though, make sure you have oil in, and don't run it for long with out water connected.
That engine had been stood 5 years I couldn't resist seeing if it ran.
Stripped it after, new gaskets, cleaned and painted.
Posted 02 February 2009 - 10:46 PM
Yea course, could probably run a hose pipe to it or set up a temporary pump and rad.
Next question, do you know of any cheap engines in the area?
Cheers,
JSG
Cheers,
JSG
Posted 02 February 2009 - 10:51 PM
Sorry mate don't, might be worth ringing Minimine see if he's got anything in.
local scrapyards might drop lucky.
We just looked on ebay and got one off there a few month ago.
