How To Secure Rear Braided Brake Lines
5 replies to this topic
#1 n20neenee
n20neenee
  • 68 posts
Posted 04 February 2009 - 12:05 AM
Hi
I have the Minispares long braided brake lines for the rear prt# C-AJJ4031B
http://www.minispare....aspx?pid=34303
Do any of you guys/girls have any pics of how you ran/secured these lines to your rear radius arms?
My thoughts were that tie wraps would wear thru the line
Sean
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 04 February 2009 - 12:13 AM
I think I debated zipping them and then just left them free and fancy.
#3 Ethel
  • 25,934 posts
Posted 04 February 2009 - 12:20 AM
A nylon cable tie isn't go to abraid stainless steel. I removed the bracket for the pipe to hose union and screwed a P clip around the hose in its place.
#4 widerim_pickup
widerim_pickup
  • 661 posts
  • Local Club: nope
Posted 04 February 2009 - 09:30 AM
I would do as ethel says remove the original bracket by grinding off rivet drill out rivet and thread it or use self tapping screw with a p clip. if your lowering the car by any amount i would recommend removing the bracket and then securing the pipe to the rear of the radius arm so there is no clearance issue with the brake pipe and bottom edge of arch like sometimes happens
Edited by widerim_pickup, 04 February 2009 - 09:32 AM.
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 04 February 2009 - 09:32 AM
cable ties
#6 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 04 February 2009 - 01:38 PM
Ive gone for free and fancy
