Sound Proofing
11 replies to this topic
#1 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 05 February 2009 - 06:43 PM
Hi all,
It has come to the stage in my project, that I am going to sound proof the inside of the Mini, mainly to keep exhaust, road, etc noise to a minimum. So, I need to know what products to use. I have read Rob Himself's Definitive Ice Guide and have decided to go for a sound proofing mat like THIS , and an absorbing sludge substance like in the guide, but I don't know any makes of this, or where to get any, so can someone help with that?
I was going to PM Rob but he has been offline since the end of November, so can anyone else help? Also let me know what you are using to sound proof the inside of your Minis and how effective they are.
#2 rozzer1275
rozzer1275
  • 439 posts
  • Local Club: ah
Posted 05 February 2009 - 07:22 PM
the over priced US stuff is trade marked dynamat, simular to that stuff, find out what thickness it is, most is about 3mm some 1.5mm and a lot cheaper but you can double it up in places.
I spoke to a prof a work about sound deadening a car and she said it is one of the worst to do.
The little of what she said that i could understand is that, the dynamat type stuff is aplied to sheet metal panels so to stop them flexing with vibrations and creating noise, buy adding weight to the panel, reducing it resinance frequency.(note it does not stick very well if applied in the cold). dont forget the inside of the doors and rear quarter panels.
another way to reduce the noise is to fit sheets of foam or simular materials to absorb the noise that is already there. this can be fitted loose under carpets above the head linning (20mm max is all i could fit under headlining). this can also be fitted under the bonnet on the bulkhead (heat resistant type) this with help absorb the noise of the engine,
also soft bushes on engine mounts/ subframe mounts reduce the vibrations to the body panels.
also as Dan said to once block any holes esp in the bulkhead.
I have striped out the standard insulation out of my car before and i needed ear plugs to drive it.
1 seperate the noise from the compartment, soft bushes, block holes
2 stop vibration panels, by adding dynamat type stuff to panels
3 absorb noise that is in the compartments, by adding absobing foam
lots of tech on here but confusing site
http://www.noisestopsystems.co.uk/
#3 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 05 February 2009 - 07:37 PM
Hmmm, very interesting, thanks for that.
#4 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 05 February 2009 - 10:06 PM
Thats the stuff I want to know about, the sludge stuff, it goes on like a paint, then expands/foams up. I just can't find any products like it.
#5 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 06 February 2009 - 06:05 PM
Anyone?
#6 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 06 February 2009 - 06:30 PM
They only thing that looks like an issue to me would be the sludge stuff. What would happen if you need to have a look at your floor pan for some reason?
#7 rozzer1275
rozzer1275
  • 439 posts
  • Local Club: ah
Posted 06 February 2009 - 06:54 PM
can get stuff that is paint on, its heavy like under seal, the foam i was refering to is in sheets and is soft. I dont know of any paint on stuff that expands into foam.
I have seen brush on sound dead stuff on ebay before, dont know if it is the type your after.
#8 chappy
chappy
  • 1,253 posts
Posted 06 February 2009 - 07:05 PM
I think you looking for this
hope it helps.
sam
#9 mini_mob
mini_mob
  • 65 posts
  • Local Club: wot no brakes
Posted 06 February 2009 - 07:16 PM
i am looking at this stuff
http://cgi.ebay.co.u...D...A1|240:1318
hope its a help
#10 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 06 February 2009 - 07:18 PM
A friend of mine bought that car of Rob_himself. And having seen it in all its glory... I can say it was probably a complete waste of time and simliar results could have been had by simply having the standard thick rubber backed bulkhead insulation on both sides (this does a fantastic job by the way if in good nick) and as mentioned previously, blocking up any holes you can find...
The Sound deadening did very little to be honest,... and made such a mess of the shell that i don't really think it was worth the hassle.
I would recommend Buying some cloud 9 under carpet sound proofing, made of a thick felt with a plastic backing, It can be cut to the shape of you carpet and then glued down to the floor. This also gives your floor a nice plush feel and doesn't make a horrid black mess of your shell on the inside. This coupled along with the standard carpet gives a very good result.
Exhaust noise is best combatted by fitting a twin box system. And road noise is greatly reduced by undersealing the car and fitting 'Dereks' arch liners... which stop the rain and road getting to the inner footwell.
#11 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 06 February 2009 - 07:49 PM
Thanks, that was the stuff I was looking for.
Thanks Retro, thats the kind of info I was looking for, might go with some of that cloud 9 stuff then.
#12 finch661
finch661
  • 2,339 posts
Posted 06 February 2009 - 08:59 PM
has any one found the sound proofing kit that minispares sell any good?
