A Series Gurus Needed Within
Posted 06 February 2009 - 07:26 AM
I don't know what this will produce but he problem is I know it's not going to be enough from what I've driven in the past; a power to weight ratio of around 130 bhp per ton would be nice. Also the car will require lead substitute and if I got an A Series to 100 bhp (car weighs 780kg) on the standard head It's going to be a bit of a pig for a daily driver.
I was going to see how I get along with my 1275 but in my heart of hearts I know I'm probably going to have to junk it for a K series/zetec. I was thinking maybe I could 16v and inject the A Series which would be the best of both worlds really.
So do you think It's possible to make a nice reasonably fuel efficent, long lasting, 100 bhp A Series?
If so what's the best route, how much roughly have you guys spent getting the A Series to this?
I've people have been putting K100 heads on the A Series all in how much has this set you back?
Thanks in advance.
Posted 06 February 2009 - 08:39 AM
Posted 06 February 2009 - 09:02 AM
Posted 06 February 2009 - 10:51 AM
Do you still have drum brakes on your Moggy... ??? if so, I'd strongly recommend you upgrade, I'm sure there's kits which will allow you to upgrade to disks on the front.
Posted 06 February 2009 - 11:14 AM
http://www.specialis...hantPageDisplay
That will give you an idea of power outputs. (My engine is the 1380 16v sprint one
In my opinion what Philc suggests would give you the power you seek but not really great for a daily drive.
The 1293 8v BMW K head from that graph was nothing expensive in terms of high spec cranks etc just what would be considered a sensible rebuild for a higher reving engine. I know you said 16v but an 8v would I reckon give you what you are looking for
Costs vary depending on what level of work you can do yourself and 8v heads are cheaper then 16v
This is the youtube video of the 1293 8v engine
There is loads of info over on efiminis, we have someone fitting a 16v in a midget also.
Ian
Posted 06 February 2009 - 11:47 AM
Posted 06 February 2009 - 11:51 AM
Have a look at the graph on this page
That will give you an idea of power outputs. (My engine is the 1380 16v sprint one)
Ian
You could achieve driveability with big cams if you used a megajolt system, again extra extra cost
Posted 06 February 2009 - 12:52 PM
well ported head £700
big cam say286 £100 may need to do folowers etc £+
1.5 roller rockers £180
may get 90hp
bit more hp with weber or twin su
the clutch should be able to handle it, (think it is a simular clutch to meastro 1.3 and 1.6 R series)
or bore too budget 1380 self ass £800
big cam (may come with engine kit)
1.5 rockers £180
should just scrape 100hp
again bit more with weber or twin su
as above but with
more expensive 1380 (say omega pistons so posible higher compressoin) £1400
105hp
again more with weber or twins
megajolt is a good, about £300 all in (+fitting and rr tune laptop required £££), it got me 2% more top end power and 19% more torque in mid range. (and it starts better, is less camy and smoother)
Posted 07 February 2009 - 10:15 AM
Posted 07 February 2009 - 03:15 PM
its basic but loads better than a dizzy
it blends figures between adanvce sites.
has a basic rev limiter.
outputs for shif lights fans pumps etc. (which I am gaing to use to turn my nos on from 3000rpm)
it can hold 2 maps and switch between them (again i will used it with nos and retared ignition when the gas is on)
have not done many miles with it so i can not comment on its reliablity.
if your going k series and keeping it standard might as well use the standard ecu.
Posted 07 February 2009 - 04:28 PM
just make sure you improve the drive train else it will not go anywhere
dave
Posted 07 February 2009 - 06:46 PM
once it has been setup eg mapped properly then it is well worth the moneyI'm going with the K series now, thanks for all the information anyway. I have one last question: how highly would you rate megajolt?
