Just Installed A Brit Part Electric Ignition
Posted 06 February 2009 - 08:14 PM
i've just installed my new britpart ignition and my new standard coil.
this may seem a daft question, but does my coil still need a condensor?
i read somewhere i didnt need one with this kit, but after taking my dizzy apart i realised there was one in there aswell. leaving me unsure.
could some one please give me answer whilst i put my new battery in.
thanks mark
Posted 06 February 2009 - 08:20 PM
I don't even think it would fit in the dizzy with the kit?
I've got one in my Elf, nice bit of kit
Shifty
Posted 06 February 2009 - 08:25 PM
Nope!!
Shifty
i have taken the points out and the condenser from the dizzy.
my question is does my coil still need one?
sorry, might not have made that clear.
Posted 06 February 2009 - 08:31 PM
If its the one in the dizzy, then not needed
Posted 06 February 2009 - 08:43 PM
Do you mean the small condensor that attaches to the coil itself, then bolts to the bracket... Pretty sure thats only a radio interference supressor, but if it is we left it on , didnt cause any problems.
yea that one, so it will run without then?
i got confused because when i was static timing my multimeter never dropped from 12v. but i was getting a spark so i used that to time instead.
i'll try n crack it up now, new batterys in. fingers crossed
Posted 06 February 2009 - 08:56 PM
it turned over a couple of times. then i tried again and nothing
im getting a click, starter solonoid i presume? but nothing else.
its more of a clunk than a click, could my starter be stuck?
i did just change the battery for at 075 because my old one was struggeling to turn over.
im supposed to be on a run tomorrow.
Edited by markaboot, 06 February 2009 - 09:02 PM.
Posted 06 February 2009 - 09:16 PM
Have you tried hitting it?
Posted 06 February 2009 - 09:30 PM
Check your earth connections in boot and on engine/firewall
not yet haha, i'll leave that till tomorrow morning. i tried pushing and rolling in gear to see if i could knock it.
going to go change my earth strap now. i did notice the wire was taped up and the bend a little too tight for my liking.
thanks
Posted 06 February 2009 - 09:51 PM
bad earth
thank you
Posted 06 February 2009 - 09:57 PM
Posted 06 February 2009 - 10:07 PM
Posted 06 February 2009 - 10:21 PM
Running like a dream now?
sounds a lot nicer. but then i have only just discovered the previous owner had fitted the wrong needle.
plus i hadnt timed it properly untill now. wont be able to tell till i take it out for a drive. which im going to do now.
its chilly tonight! my hands are stinging from the warmth inside. my spot light broke as well tonight so i've been doing everything with the light on my fone.
not had a good night so far, its looking better now tho.
