Does anyone know how you attach a grp battery box???
Is it rivetted or what?
Battery Box
Will
, Aug 13 2005 07:45 PM
5 replies to this topic
Posted 13 August 2005 - 07:45 PM
Posted 13 August 2005 - 10:10 PM
One would assume bonded using a resin or something ??
Posted 13 August 2005 - 10:11 PM
cool, just wonderin whether i replace with fibreglass or metal...
Posted 14 August 2005 - 01:18 PM
Battery box, fit it behind the seats, bolt to floor.
As long as you dont have rear passengers that is. Otherwise you have to mount it in the boot, but it sits onto of the boot floor not in the recess of the standard battery box.
Smudger
Smudger
Posted 14 August 2005 - 09:35 PM
Does the box stop the battery bouncing around? My battery used to jump about so much on corners that it would disconnect randomly in the middle of journeys! ...I just shoved 2 tennis balls down there and it did the trick!
Posted 15 August 2005 - 07:16 AM
For my road cars i use some thin(ish) polystryne(?) sheet to keep the battery warm & stable (if that makes sense) and for the Mozzie, then the battery will either be a bike battery or Red Top/Optima so will have different battery box for that, and just bolted straight to floor/bulkhead depending on where it is needed weight wise.
Smudger
Smudger
